.NET
cao.dbconnect, read labels from xref
2 REPLIES 2
mendesva
623 Views, 2 Replies
Hi everybody...
I'm trying to read and update labels from Xrefs.
The meaning of it is to Reload all Labels in the Xrefs before I plot any Layout.
Autocad is working in SingleDrawing mode.
What do I have to do to bring xDB and dbConn together so I can "read/reload" the Labels?
Here is a snippet of my code (which doesn't work as expected) Smiley Sad
Thank you for any kind of help.
(System: Win 7 64bit, Autocad 2012 64bit, VB express 2010)
Dim xDB As New Database(False, False)
xDB.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, False, "")
Dim acApp As Autodesk.AutoCAD.Interop.AcadApplication = DirectCast(Application.AcadApplication, Autodesk.AutoCAD.Interop.AcadApplication)
Dim acDoc As Autodesk.AutoCAD.Interop.AcadDocument = Application.DocumentManager.GetDocument(xDB).AcadDocument
Dim dbConn As CAO.DbConnect = acApp.GetInterfaceObject("CAO.DBConnect.16")
Dim lbls As CAO.LabelTemplates = dbConn.GetLabelTemplates()
Dim lnks As CAO.LinkTemplates = dbConn.GetLinkTemplates()
2 REPLIES 2
What is the problem you are facing? Usually when creating Database to ReadDwgFile we use
Dim xDB As New Database(False, True)
Can you try that?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Thank you for your reply Augusto,
I tried both: Database(False, False) and Database(False, True)
I don't know where exactly the problem is. All I know is that this two lines of code don't bring any result.
lbls ans lkns are empty!
So I guess dbConn.GetLabelTemplates() doesn't read from acDoc.
What do I have to do/change so lbls and lnks represent the labels and links in my Xref?
”Boost
