.NET
osayed3202
Message 1 of 11 (245 Views)
cannot werit in the memorry
245 Views, 10 Replies
01-14-2014 06:20 AM
Hi guys,
I am working in project that purge and audit a bunch of file selected in listview control, the code shows the code generates errors cannot write in the memory and stopes in the red line.
DocumentCollection acdMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
string strFullPath;
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction Tx = db.TransactionManager.StartTransaction())
app.ActiveDocument.SendCommand("regen ");
app.ActiveDocument.PurgeAll();
app.ActiveDocument.AuditInfo(true);
RegAppTable table = Tx.GetObject(db.RegAppTableId, OpenMode.ForRead) as RegAppTable;
ObjectIdCollection regIds = new ObjectIdCollection();
foreach (ObjectId id in table)
regIds.Add(id);
//this function will remove all
//app names which are used in the drawing file
db.Purge(regIds);
foreach (ObjectId id in regIds)
DBObject obj = Tx.GetObject(id, OpenMode.ForWrite);
// the program stops here, cannot write on the memory
obj.Erase();
Tx.Commit();
Best Regards
O.Sayed
CAD developer
You have to lock the document before doing any Operation. Probably you are using this Event from a non-modal form, this is why , it is occuring.
You did not read my post carefully. I wrote that you should wrap your code in:
using(DocumentLock docLock = doc.LockDocument()) {
// your's code here!
 But you ignore me... Sorry... :smileysad: That is why exception eLockViolation occur!
Alfred.NESWADBA
Message 2 of 11 (232 Views)
Re: cannot werit in the memorry
01-14-2014 08:02 AM in reply to: osayed3202
I would verify if the id is valid and is not erased before open it for write.
- alfred -
Alfred NESWADBA
osayed3202
Message 3 of 11 (211 Views)
01-15-2014 01:31 AM in reply to: Alfred.NESWADBA
thank you very much fo your support and time.
would you please clarify what you mean.
Best Regards
O.Sayed
CAD developer
mzakiralam
Message 4 of 11 (201 Views)
01-15-2014 04:02 AM in reply to: osayed3202
What Alfred suggested you to verify the id something like below:
If id IsNot Nothing
End If
Alfred.NESWADBA
Message 5 of 11 (193 Views)
01-15-2014 11:25 AM in reply to: osayed3202
Before opening objects for read/write I meant to verify the validity of the ObjectID:
if (Id.IsValid) andalso (not Id.IsErased) then
...now you can access the object in read/write mode.
HTH, - alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 6 of 11 (185 Views)
01-15-2014 02:06 PM in reply to: osayed3202
osayed3202 wrote:
Hi guys,
Do I understand correctly that you open many files sequentially? Appropriately you work in the context of the application and must lock document.
  using (Transaction Tx = db.TransactionManager.StartTransaction()) {
    // your's code ...
I also moved code using app.ActiveDocument before the transaction...
Also I checked id before add it to regIds:
foreach (ObjectId id in table) {
  if (!id.IsErased && !id.IsEffectivelyErased)
     regIds.Add(id);
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
osayed3202
Message 7 of 11 (135 Views)
01-20-2014 01:03 AM in reply to: Alexander.Rivilis
//string strTextFileName = SaveDialog.FileName; foreach (ListViewItem itemRow in this.lstView.Items) { ListViewItem item = lstView.Items[itemRow.Index]; string lines = item.SubItems[0].Text; string col = item.SubItems[1].Text; strFullPath = col + "\\" + lines; AcadApplication app = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication; app.Documents.Open(strFullPath); if (chkBoxUnregApp == true) { app.ActiveDocument.SendCommand("regen "); app.ActiveDocument.PurgeAll(); app.ActiveDocument.PurgeAll(); app.ActiveDocument.AuditInfo(true); app.ActiveDocument.SendCommand("regen "); using (Transaction Tx = db.TransactionManager.StartTransaction()) { RegAppTable table = Tx.GetObject(db.RegAppTableId, OpenMode.ForRead) as RegAppTable; ObjectIdCollection regIds = new ObjectIdCollection(); foreach (ObjectId id in table) { if (!id.IsErased && !id.IsEffectivelyErased) regIds.Add(id); } //this function will remove all //app names which are used in the drawing file db.Purge(regIds); if (regIds != null) { foreach (ObjectId id in regIds) { DBObject obj = Tx.GetObject(id, OpenMode.ForWrite); // the program stops here, cannot write on the memory obj.Erase(); } } Tx.Commit(); } }
Dear Alexander,
I changed the code as you see above but the error appear like the attached image shows it cannot write in the file eLockViolation.
Thanks for all of you for your time
Osayed
Best Regards
O.Sayed
CAD developer
mzakiralam
Message 8 of 11 (134 Views)
01-20-2014 01:13 AM in reply to: osayed3202
Moderator
Alexander.Rivilis
Message 9 of 11 (118 Views)
01-20-2014 03:42 AM in reply to: osayed3202
osayed3202
Message 10 of 11 (107 Views)
01-20-2014 06:08 AM in reply to: Alexander.Rivilis
Yeaaa it works now thanks guys for your time and support,
but unfortunatly when the current file finishes  and when openning another file from the listview it bring Fatal error message that always happen at the second dwg file.
Am I have to dispose or somthing like this
the code here and also the fatal erroe image attached.
thanks alot guys.
                                        regIds.Add(id);
                                db.Purge(regIds);
                                if (regIds != null)
                                    using (DocumentLock docLock = doc.LockDocument())
                                        obj.Erase();
                                Tx.Commit();
Best Regards
O.Sayed
CAD developer
