.NET
cannot werit in the memorry
10 REPLIES 10
Message 1 of 11
1094 Views, 10 Replies
Hi guys,
I am working in project that purge and audit a bunch of file selected in listview control, the code shows the code generates errors cannot write in the memory and stopes in the red line.
DocumentCollection acdMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
string strFullPath;
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction Tx = db.TransactionManager.StartTransaction())
app.ActiveDocument.SendCommand("regen ");
app.ActiveDocument.PurgeAll();
app.ActiveDocument.AuditInfo(true);
RegAppTable table = Tx.GetObject(db.RegAppTableId, OpenMode.ForRead) as RegAppTable;
ObjectIdCollection regIds = new ObjectIdCollection();
foreach (ObjectId id in table)
regIds.Add(id);
//this function will remove all
//app names which are used in the drawing file
db.Purge(regIds);
foreach (ObjectId id in regIds)
DBObject obj = Tx.GetObject(id, OpenMode.ForWrite);
// the program stops here, cannot write on the memory
obj.Erase();
Tx.Commit();
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
I would verify if the id is valid and is not erased before open it for write.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 11
in reply to: Alfred.NESWADBA
thank you very much fo your support and time.
would you please clarify what you mean.
Message 4 of 11
What Alfred suggested you to verify the id something like below:
If id IsNot Nothing
End If
Message 5 of 11
Alfred.NESWADBA
Before opening objects for read/write I meant to verify the validity of the ObjectID:
if (Id.IsValid) andalso (not Id.IsErased) then
...now you can access the object in read/write mode.
HTH, - alfred -
Alfred NESWADBA
Message 6 of 11
Alexander.Rivilis
@Anonymous wrote:
Hi guys,
Do I understand correctly that you open many files sequentially? Appropriately you work in the context of the application and must lock document.
using(DocumentLock docLock = doc.LockDocument()) {
  using (Transaction Tx = db.TransactionManager.StartTransaction()) {
    // your's code ...
I also moved code using app.ActiveDocument before the transaction...
Also I checked id before add it to regIds:
foreach (ObjectId id in table) {
  if (!id.IsErased && !id.IsEffectivelyErased)
     regIds.Add(id);
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 7 of 11
in reply to: Alexander.Rivilis
//string strTextFileName = SaveDialog.FileName; foreach (ListViewItem itemRow in this.lstView.Items) { ListViewItem item = lstView.Items[itemRow.Index]; string lines = item.SubItems[0].Text; string col = item.SubItems[1].Text; strFullPath = col + "\\" + lines; AcadApplication app = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication; app.Documents.Open(strFullPath); if (chkBoxUnregApp == true) { app.ActiveDocument.SendCommand("regen "); app.ActiveDocument.PurgeAll(); app.ActiveDocument.PurgeAll(); app.ActiveDocument.AuditInfo(true); app.ActiveDocument.SendCommand("regen "); using (Transaction Tx = db.TransactionManager.StartTransaction()) { RegAppTable table = Tx.GetObject(db.RegAppTableId, OpenMode.ForRead) as RegAppTable; ObjectIdCollection regIds = new ObjectIdCollection(); foreach (ObjectId id in table) { if (!id.IsErased && !id.IsEffectivelyErased) regIds.Add(id); } //this function will remove all //app names which are used in the drawing file db.Purge(regIds); if (regIds != null) { foreach (ObjectId id in regIds) { DBObject obj = Tx.GetObject(id, OpenMode.ForWrite); // the program stops here, cannot write on the memory obj.Erase(); } } Tx.Commit(); } }
Dear Alexander,
I changed the code as you see above but the error appear like the attached image shows it cannot write in the file eLockViolation.
Thanks for all of you for your time
Osayed
Message 8 of 11
You have to lock the document before doing any Operation. Probably you are using this Event from a non-modal form, this is why , it is occuring.
Message 9 of 11
Alexander.Rivilis
You did not read my post carefully. I wrote that you should wrap your code in:
// your's code here!
 But you ignore me... Sorry... 😞 That is why exception eLockViolation occur!
Expert Elite Member
Message 10 of 11
Yeaaa it works now thanks guys for your time and support,
but unfortunatly when the current file finishes  and when openning another file from the listview it bring Fatal error message that always happen at the second dwg file.
Am I have to dispose or somthing like this
the code here and also the fatal erroe image attached.
thanks alot guys.
                                        regIds.Add(id);
                                db.Purge(regIds);
                                if (regIds != null)
                                    using (DocumentLock docLock = doc.LockDocument())
                                        obj.Erase();
                                Tx.Commit();
Message 11 of 11
hi Guys i checked but I found the fatal error has been produced at using transaction line but when i use the Tx.Dispose()
thanks alot
”Boost
