.NET
Cannot remove events in AutoCAD 2008?
11 REPLIES 11
Message 1 of 12
703 Views, 11 Replies
Is this a bug in AutoCAD 2008? After I execute the "StopCapturecircles" command in the following codes,the "ObjectAppended" event handler is still be executed?
using AAAS = Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Internal;
namespace eventbug
public class ggClass
private const string New_bolthole_layer = "BoltHoleLayer";
[CommandMethod("capturelines")]
static public void Capturecircles()
Database db = AAAS.Application.DocumentManager.MdiActiveDocument.Database;
ggClass.gg_Creatlayer(New_bolthole_layer, db);
db.ObjectAppended += new ObjectEventHandler(ObjectAppended);
[CommandMethod("StopCapturecircles")]
static public void stopCapturecircles()
db.ObjectAppended -= new ObjectEventHandler(ObjectAppended);
static private void gg_Creatlayer(string layername, Database db)
using (Transaction trans = db.TransactionManager.StartTransaction())
ObjectId layertableid = db.LayerTableId;
LayerTable layers = (LayerTable)trans.GetObject(layertableid, OpenMode.ForRead);
if (layers.Has(layername))
return;
else
LayerTableRecord newlayer = new LayerTableRecord();
newlayer.Name = layername;
layers.UpgradeOpen();
layers.Add(newlayer);
trans.AddNewlyCreatedDBObject(newlayer, true);
trans.Commit(); trans.Dispose();
static void ObjectAppended(object sender, ObjectEventArgs e)
//throw new System.Exception("The method or operation is not implemented.");
if (e.DBObject is Line)
Line newLine = e.DBObject as Line;
newLine.UpgradeOpen();
if (newLine.IsWriteEnabled)
newLine.Layer = New_bolthole_layer;
11 REPLIES 11
Message 2 of 12
Congradulations.
Defect confirmed.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5584661@discussion.autodesk.com...
namespace eventbug
return;
else
Message 3 of 12
Shouldn't you be removing the handler you added in Capturecircles?
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Message 4 of 12
Hi Owen.
He does remove it (in stopCapturecircles())
but the event continues to fire.
"Owen Wengerd" wrote in message news:5585957@discussion.autodesk.com...
Owen Wengerd
Message 5 of 12
Tony:
Excuse my .NET ignorance, but to me it looks like he is creating a new
handler, then trying to remove the new one while leaving the old one in
place. No?
Owen Wengerd
Message 6 of 12
"Owen Wengerd" wrote:
>> it looks like he is creating a new handler, then
>> old one in place. No?
Yes it appears that way because the names of the
types are confusing. The 'handler' is the method of
the class that is called to handle the event. The
object he creates via 'new ObjectEventHandler()', is
actually a reference to the handler (which is passed
as the parameter).
Message 7 of 12
Tony:
Ok, I see what you're saying. I wonder though if the "reference to the
handler" isn't really a thunk which simply passes control to the actual
handler. If this were the case, the 'handler' from AutoCAD's perspective
would be the instance of the thunk. That is, different instances of the
thunk would appear to AutoCAD as different event handlers, and would
presumably result in the behavior that the OP is observing.
For the record, I'm pretty much clueless when it comes to .NET, so this is
all wild speculation on my part. 🙂
Owen Wengerd
"Tony Tanzillo" wrote in message
news:5587182@discussion.autodesk.com...
as the parameter).
Message 8 of 12
The codes run well in AutoCAD07.. Message was edited by: csharpbird
Message 9 of 12
Confirmed
~'J'~
Message 10 of 12
I wouldn't call it a thunk, just a class that contains
the info needed to invoke the handler.
The main thing is that I also have code that was
affected by this and worked just fine in '07, but in
'08 with the exact same code, the event continues
to fire even after its removed.
"Owen Wengerd" wrote in message news:5587382@discussion.autodesk.com...
Tony:
Owen Wengerd
as the parameter).
Message 11 of 12
Ed.Jobe
Is this typical of all events or just this one?
Ed
How to post your code.
Message 12 of 12
Don't know, haven't checked yet.
wrote in message news:5589306@discussion.autodesk.com...
”Boost
