Hi
I have been working for some time on an application where i access AutoCAD from within an exe. i know that this is not the optimal way to do things and I expect to convert the code to a dll but for now I need to keep the existing application accessing the com.
That has been working for some time, but now suddenly I get the errors:
Cannot find wrapper assembly for type library "AutoCAD"
Cannot find wrapper assembly for type library "AXDBLib"
Cound not resolve dependent COM reference "ffc2a8db-a497- ..." version 1.0
The referenced component "AutoCAD" could not be found
The referenced component "AXDBLib could not be found
The referenced component "ObjClassImpLib could not be found
Then I made sure that the proper tlb-files exist and run a repair on my AutoCAD MEP 2010 installation. That did not help.
Maybe trying - not succeding to install Autodesk Design Reviiew 2011 + DWG Trueview had a negative impact on the wrapper?
I am using VB code in Visual Studio 2010.
Can anyone explain what is happening and how to solve this issue?
Well I guess that nobody have a solution to this issue. However I found one ...
1. Completely uninstall AutoCAD.
2. Reinstall AutoCAD once again.
... thought that you guys just might want to know 😉
Regards
Jan Grenov
Daem, I´ve gone´even less hair since I started my class in 3Dsm.
As an old Mac user this is my definition of nightmare: Lost or broken .DLL files.
I´ll try to reinstall as you said and If it works I might sleep well again.
