.NET
New Member
jhanel
Message 1 of 2 (188 Views)
Cannot debug 64-bit DLL
188 Views, 1 Replies
07-25-2012 09:45 AM
When I try to connect to even the sample code provided in the ObjectARX SDK, my AutoCAD instance hangs and must be forcibly closed. If I don't connect to it with a debugger, the sample code works just fine.
This is also happening with my specific DLL, but I wanted to see if I'd done something stupid, or if it was a system problem, so I loaded up the EllipseJig plugin that comes with the ObjectARX SDK. It locks up too.
Without being able to debug my DLL, I am unable to determine what's going on under the hood with one of my numbering schemes for objects within a drawing. It's far too complicated to walk through the code line-by-line visually. I mean, it could be done, but I'd like to be able to solve the problem sometime before next year and being able to use Visual Studio would greatly help. =)
My setup:
AutoCAD Mechanical. Version F.51.0.0
Visual Studio 2010 Professional.Version 10.0.30319.1
Any thoughts ideas about what is going wrong? I've uninstalled/reinstalled AutoCAD and VS2010 three times. I'm quite convinced that neither of these tools is currently corrupt. I'm compiling on a 64-bit machine, and using a 64-bit version of AutoCAD if that helps any.
Active Contributor
tomg
Message 2 of 2 (176 Views)
Re: Cannot debug 64-bit DLL
07-25-2012 01:20 PM in reply to: jhanel
Can you look in the Windows error logs? There may be something there that will lead to the answer.
