.NET
cannot create activex component
3 REPLIES 3
2734 Views, 3 Replies
Dim AcadApp As AcadApplication
Try
                AcadApp = GetObject(, "AutoCAD.Application")\
Catch ex As Exception
               AcadApp = CreateObject("AutoCAD.Application")
End Try
               AcadApp.Visible = True
I have used the above code to open an AUTOCAD drawing and read the objects. But i am getting an error like 'cannot create activex component'. when the AUTOCAD drawing takes time to load, this error is coming.
Can anyone help me out from this issue.
Thank you.
3 REPLIES 3
StephenPreston
Your problem appears to be the same as this one - http://forums.autodesk.com/t5/NET/Create-autocad-2012-COM-object/m-p/4728197.
Cheers,
Stephen Preston
Autodesk Developer Network
i am not able to open the given link.
Below message is displayed,
Virupaksha_aithal
Hi
try removing the "." at the end in link like http://forums.autodesk.com/t5/NET/Create-autocad-2012-COM-object/m-p/4728197
Virupaksha Aithal KM
Developer Technical Services
”Boost
