.NET
Cancel command
3 REPLIES 3
327 Views, 3 Replies
Cancel command
Hi.
Is it a way to cancel a command? My program makes a group with a leader
attach to a mtext and other entitys. It is importent
that only my program can edit the mtext, and it should be impossible to
explode the group. So it something i can do in for inctance in
ObjectModifed event? I have xdata in group and mtext so i want to cancel
ddedit and explode when when that is selected
Rune
3 REPLIES 3
How about watching the selectionadded event for your
entity. If any command you don't want run on it is active
then remove it from the selection set.
Bobby C. has a sample here.
http://www.theswamp.org/index.php?topic=8194.0
"Rune Aarnes" wrote in message
news:5260153@discussion.autodesk.com...
Hi.
Rune
Thank you very much. I will try this....
"Paul Richardson" skrev i melding
news:5260300@discussion.autodesk.com...
Hi.
Rune
Hi
Now I have tryed it and it works fine to filter out the group i dont want to
explode, but I cant fine out how to cancel a command...
I would be very happy if somebody can give me a little tip how to do it....
"Rune Aarnes" skrev i melding
news:5262512@discussion.autodesk.com...
Hi.
Rune
”Boost
