.NET
Active Contributor
1 Kudo
Post 1 of 7
Cancel change active document
454 Views, 6 Replies
01-24-2013 06:19 AM
Hi
How can I stop changing active document?
I was thinking I could use this, but I don't know how to cancel it in the event handler:
AcadApp.DocumentManager.DocumentToBeActivated += new DocumentCollectionEventHandler(DocumentManager_DocumentToBeActivated);
static void DocumentManager_DocumentToBeActivated(object sender, DocumentCollectionEventArgs e)
    // Messagebox to ask if user are sure
    bool AreYouSureYouWantToChangeActiveFile = MessageBox....
    if(!AreYouSureYouWantToChangeActiveFile)
        //cancel change active file somehow...???
1. You can disable switching of Document's at all if you call:
AcadApp.DocumentManager.DocumentActivationEnabled = false;
 but not in handler of event of DocumentToBeActivated.
2. If you have to prevent switching in a handler of event of DocumentToBeActivated you have to:
a) save previous Document and set flag of switching in this handler.
b) in command reactor switch Document back to previous Document and clear flag of switching.
Moderator
277 Kudos
Post 2 of 7
Re: Cancel change active document
01-24-2013 01:47 PM in reply to: Fredrik.Larsen
DocumentCollection.DocumentActivationEnabled property can help you
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
1 Kudo
Post 3 of 7
01-25-2013 12:06 AM in reply to: Alexander.Rivilis
Hi
I could not get it to work. When I set the property you mentioned the active document has already changed. And if I set the property to false at a earlier stage I will never come to the listener. Any ideas?
            DialogResult dialogResult = MessageBox.Show("You are changing the active drawing. Continue?", "Active drawing change", MessageBoxButtons.YesNo);
            if (dialogResult == DialogResult.Yes)
                AcadApp.DocumentManager.DocumentActivationEnabled = true;
                RemoveDocumentToBeActivatedListener();
            else if (dialogResult == DialogResult.No)
Moderator
277 Kudos
Post 4 of 7
01-25-2013 01:23 AM in reply to: Fredrik.Larsen
Valued Mentor
175 Kudos
Post 5 of 7
01-28-2013 01:22 AM in reply to: Fredrik.Larsen
Perhaps you can explain why you want to prevent a document from being activated?
Active Contributor
1 Kudo
Post 6 of 7
01-28-2013 01:29 AM in reply to: DiningPhilosopher
I have created an application that scans and does something with the active document and I haven't implemented support for what happens when active document is changed. So for my demo version I thought I could just prevent the user from changing the document.
Moderator
277 Kudos
Post 7 of 7
01-28-2013 01:45 AM in reply to: Fredrik.Larsen
While command with CommandFlags.Modal is active user can not switch active document. More precisely when switching to another document, the command will paused and wait for switch back.
