.NET
Can't draw text in new UCS
3 REPLIES 3
hoathuongphuoc
756 Views, 3 Replies
Hi al,
I have a problem, hope everybody can help me. This is, I tried change new ucs in my autocad by vb.net but when i have new UCS so i can not draw text in this new UCS. This is my code:
    <CommandMethod("ROTZ")> _
    Public Sub ShowHatchDialog()
        Dim ar As New ArrayList()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = acDoc.Database
        Dim ucs As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
        Dim cs As CoordinateSystem3d = ucs.CoordinateSystem3d
        Dim pro As New PromptPointOptions("")
        For i As Integer = 0 To 1
            Dim ptResult As PromptPointResult = acDoc.Editor.GetPoint(pro)
            If ptResult.Status <> PromptStatus.OK Then
                Return
            ar.Add(ptResult.Value)
        Next
        Dim pt1 As Point3d = ar.Item(0)
        Dim pt2 As Point3d = ar.Item(1)
        Dim zAxis As Vector3d = acDoc.Editor.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis
        Dim xAxis As Vector3d = pt1.GetVectorTo(pt2)
        Dim yAxis As Vector3d = xAxis.GetPerpendicularVector
        Dim Rot As Matrix3d = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, pt1, xAxis, yAxis, zAxis)
        acDoc.Editor.CurrentUserCoordinateSystem = Rot
        acDoc.Editor.Regen()
        '' Start a transaction
        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                            OpenMode.ForWrite)
            ''Create a single-line text object
            Dim dText As DBText = New DBText()
            dText.SetDatabaseDefaults()
            dText.Position = New Point3d(pt2.X, pt2.Y, 0).TransformBy(Rot)
            dText.Height = 1
            '' condition add floor
            dText.TextString = "6"
            '' Add the new object to the block table record and the transaction
            acBlkTblRec.AppendEntity(dText)
            acTrans.AddNewlyCreatedDBObject(dText, True)
            '' Save the new object to the database
            acTrans.Commit()
        End Using
    End Sub
Thanks All.
3 REPLIES 3
Hallex
in reply to: hoathuongphuoc
Not sure about if this would be a solution,
anyway try instead:
        <CommandMethod("TUCS")> _
        Public Sub TestTextInNewUCS()
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim cs As CoordinateSystem3d = ucs.CoordinateSystem3d ''<-- you may want before to store current ucs to a variable say 'CUCS', then revert back at the end
            Dim pro As New PromptPointOptions("Pick first point: ")
                pro.Message = vbLf + "Pick second point: "
                    Return
            Next
            Dim xAxis As Vector3d = pt1.GetVectorTo(pt2).GetNormal() '<-- ! to get an init vector !
                                                OpenMode.ForWrite)
                dText.Position = New Point3d(pt2.X, pt2.Y, 0).TransformBy(Rot.Inverse)
                'Dim pt As Point3d = New Point3d(pt2.X, pt2.Y, 0)
                dText.Height = 1
                ' Put text location to the newly created ucs
                dText.TransformBy(Rot)
                acTrans.Commit()
            End Using
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
hoathuongphuoc
in reply to: Hallex
Thanks so much. I have find good solution. This is, I instead
dText.Position=New Point3d(pt2.X, pt2.Y,o).TransformBy(ucs)
for
Hallex
Glad if I could help
Cheers 🙂
”Boost
