.NET
Valued Contributor
0 Kudos
Post 1 of 4
Can't draw text in new UCS
280 Views, 3 Replies
12-15-2013 10:29 PM
Hi al,
I have a problem, hope everybody can help me. This is, I tried change new ucs in my autocad by vb.net but when i have new UCS so i can not draw text in this new UCS. This is my code:
    <CommandMethod("ROTZ")> _
    Public Sub ShowHatchDialog()
        Dim ar As New ArrayList()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = acDoc.Database
        Dim ucs As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
        Dim cs As CoordinateSystem3d = ucs.CoordinateSystem3d
        Dim pro As New PromptPointOptions("")
        For i As Integer = 0 To 1
            Dim ptResult As PromptPointResult = acDoc.Editor.GetPoint(pro)
            If ptResult.Status <> PromptStatus.OK Then
                Return
            End If
            ar.Add(ptResult.Value)
        Next
        Dim pt1 As Point3d = ar.Item(0)
        Dim pt2 As Point3d = ar.Item(1)
        Dim zAxis As Vector3d = acDoc.Editor.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis
        Dim xAxis As Vector3d = pt1.GetVectorTo(pt2)
        Dim yAxis As Vector3d = xAxis.GetPerpendicularVector
        Dim Rot As Matrix3d = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, pt1, xAxis, yAxis, zAxis)
        acDoc.Editor.CurrentUserCoordinateSystem = Rot
        acDoc.Editor.Regen()
        '' Start a transaction
        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                            OpenMode.ForWrite)
            ''Create a single-line text object
            Dim dText As DBText = New DBText()
            dText.SetDatabaseDefaults()
            dText.Position = New Point3d(pt2.X, pt2.Y, 0).TransformBy(Rot)
            dText.Height = 1
            '' condition add floor
            dText.TextString = "6"
            '' Add the new object to the block table record and the transaction
            acBlkTblRec.AppendEntity(dText)
            acTrans.AddNewlyCreatedDBObject(dText, True)
            '' Save the new object to the database
            acTrans.Commit()
        End Using
    End Sub
Thanks All.
Not sure about if this would be a solution,
anyway try instead:
 <CommandMethod("TUCS")> _
Public Sub TestTextInNewUCS()
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim cs As CoordinateSystem3d = ucs.CoordinateSystem3d ''<-- you may want before to store current ucs to a variable say 'CUCS', then revert back at the end
Dim pro As New PromptPointOptions("Pick first point: ")
pro.Message = vbLf + "Pick second point: "
Return
End If
Next
Dim xAxis As Vector3d = pt1.GetVectorTo(pt2).GetNormal() '<-- ! to get an init vector !
OpenMode.ForWrite)
dText.Position = New Point3d(pt2.X, pt2.Y, 0).TransformBy(Rot.Inverse)
'Dim pt As Point3d = New Point3d(pt2.X, pt2.Y, 0)
dText.Height = 1
' Put text location to the newly created ucs
dText.TransformBy(Rot)
acTrans.Commit()
End Using
End Sub
171 Kudos
Post 2 of 4
Re: Can't draw text in new UCS
12-16-2013 03:00 AM in reply to: hoathuongphuoc
anyway try instead:
                    Return
                End If
            Next
                                                OpenMode.ForWrite)
                dText.Height = 1
                acTrans.Commit()
            End Using
        End Sub
Valued Contributor
0 Kudos
Post 3 of 4
12-16-2013 06:29 PM in reply to: Hallex
Thanks so much. I have find good solution. This is, I instead
dText.Position=New Point3d(pt2.X, pt2.Y,o).TransformBy(ucs)
for
171 Kudos
Post 4 of 4
12-16-2013 09:23 PM in reply to: hoathuongphuoc
Glad if I could help
Cheers :smileyhappy:
