.NET
wang890
Message 1 of 7 (733 Views)
can't dispose xdata
733 Views, 6 Replies
02-13-2012 05:26 PM
i have a combo box which choose from 3 items one is blank. the triggered item changed event will erase the old set of corresponding xdata in the selected object and populate with new ones read from different text boxes. i was able to set the xdata for the first time ok. but when trying to dispose it won't dispose.
Imports System.Runtime
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.DatabaseServices
Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Create_Pipe_Data.ActiveDrawing
Public Class Container1
    Public oSelectedObjID As ObjectId
    Public WithEvents doc As Document
    Public AppName As String = "CreatePipeData"
    Private m_DocData As MyDocData = Nothing
    Friend Shared ps As Autodesk.AutoCAD.Windows.PaletteSet = Nothing
    Dim myPalette As Container1
    <CommandMethod("tp", CommandFlags.Transparent)> _
Public Sub DoIt()
        If m_DocData Is Nothing Then m_DocData = New MyDocData
        AddHandler AcApp.DocumentManager.DocumentActivated, AddressOf Me.DocumentManager_DocumentActivated
        AddHandler AcApp.DocumentManager.DocumentToBeDeactivated, AddressOf Me.DocumentManager_DocumentToBeDeactivated
        'check to see if paletteset is already created
        If ps Is Nothing Then
            'no so create it
            ps = New Autodesk.AutoCAD.Windows.PaletteSet("Create Pipe Data")
            'create new instance of user control
            myPalette = New Container1()
            'add it to the paletteset
            ps.Add("Create Pipe Data", myPalette)
        End If
        'turn it on
        ps.Visible = True
    End Sub
    Private Sub AddRegAppTableRecord(ByVal regAppName As String)
        Dim db As Database = doc.Database
        Dim tr As Transaction = doc.TransactionManager.StartTransaction()
        Try
            Using tr
                Dim rat As RegAppTable = DirectCast(tr.GetObject(db.RegAppTableId, OpenMode.ForRead, False), RegAppTable)
                If Not rat.Has(regAppName) Then
                    rat.UpgradeOpen()
                    Dim ratr As New RegAppTableRecord()
                    ratr.Name = regAppName
                    rat.Add(ratr)
                    tr.AddNewlyCreatedDBObject(ratr, True)
                End If
                tr.Commit()
            End Using
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
    Private Sub Container1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        doc = Application.DocumentManager.MdiActiveDocument
        'doc.LockDocument(DocumentLockMode.Write, Nothing, Nothing, True)
        ' AddHandler doc.ImpliedSelectionChanged, AddressOf ObjectSelected
        'AddHandler doc.ImpliedSelectionChanged, AddressOf ObjectSelected
    End Sub
    Private Sub DocumentManager_DocumentActivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
        'display the current active document
        Try
            If Not m_DocData Is Nothing Then
                txtADwg.Text = m_DocData.Current.Stuff
            End If
            MsgBox(ex.Message)
        End Try
    End Sub
    Private Sub DocumentManager_DocumentToBeDeactivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
        'store the current contents
        Try
                m_DocData.Current.Stuff = txtADwg.Text
            End If
            MsgBox(ex.Message)
        End Try
    End Sub
    Private Sub ObjectSelectEvent(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles doc.ImpliedSelectionChanged
        ObjectSelected()
    End Sub
    Private Sub ObjectSelected()
        'Dim myDB As Database = HostApplicationServices.WorkingDatabase
        Dim myEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim PossibleSelectionSet As PromptSelectionResult = myEditor.SelectImplied
        Dim mySelectionSet As SelectionSet = Nothing
        Dim myObjectIDs As New List(Of ObjectId)
        Dim oSelectedObj As DBObject
        If PossibleSelectionSet.Status = PromptStatus.OK Then
            Using tr As Transaction = doc.TransactionManager.StartTransaction
                mySelectionSet = PossibleSelectionSet.Value
                For Each mySelObj As SelectedObject In mySelectionSet
                    myObjectIDs.Add(mySelObj.ObjectId)
                Next
            End Using
        End If
        'SET TO LAST OBJECT SELECTED
        If myObjectIDs.Count <> 0 Then
            Try
                Using oLock As DocumentLock = doc.LockDocument() '(DocumentLockMode.Write, Nothing, Nothing, True)
                    Using tr
                        oSelectedObj = tr.GetObject(myObjectIDs.Item(myObjectIDs.Count - 1), OpenMode.ForRead, False)
                        oSelectedObjID = oSelectedObj.ObjectId
                        'AFTER SELECT OBJECT, POPULATE FORM
                        PopulateXdataToForm(oSelectedObjID)
                    End Using
                End Using
                GroupBox1.Enabled = True
                MsgBox(ex.Message)
            End Try
        Else
            GroupBox1.Enabled = False
        End If
    End Sub
    Private Sub txtType_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles txtType.MouseLeave
        PopulateFormDataToObjectXdata(oSelectedObjID)
    End Sub
    Private Sub txtMaterial_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtMaterial.MouseLeave, TextBox6.MouseLeave, TextBox5.MouseLeave, TextBox4.MouseLeave, TextBox3.MouseLeave, TextBox2.MouseLeave, TextBox1.MouseLeave
    End Sub
    Private Sub txtLength_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtLength.MouseLeave
    End Sub
    Private Sub txtInvOut_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtInvOut.MouseLeave
    End Sub
    Private Sub txtInvIn_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtInvIn.MouseLeave
    End Sub
    Private Sub txtGrade_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtGrade.MouseLeave
    End Sub
    Private Sub TxtDiameter_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtDiameter.MouseLeave
    End Sub
    Private Sub cmbPipeOrStructure_SelectionChangeCommitted(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmbPipeOrStructure.SelectionChangeCommitted
        PipeStructureChanged()
    End Sub
    Private Sub PipeStructureChanged()
        If cmbPipeOrStructure.Text = "Pipe" Then
            gpbPipe.Enabled = True
            gpbStructure.Enabled = False
                Using tr
                    'Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False)
                    'If oSelectedObj.XData <> Nothing Then
                    '    Dim rb As ResultBuffer = oSelectedObj.XData
                    '    rb.Dispose()
                    'End If
                    'tr.Commit()
                End Using
            End Using
        ElseIf cmbPipeOrStructure.Text = "Structure" Then
            gpbStructure.Enabled = True
            gpbPipe.Enabled = False
                Using tr
                    '    rb.Dispose()
                    'End If
                    'tr.Commit()
                End Using
            End Using
        ElseIf cmbPipeOrStructure.Text = "" Then
            ClearTextbox()
                Using tr
                    '    rb.Dispose()
                    'End If
                    'tr.Commit()
                End Using
            End Using
        End If
    End Sub
    Private Sub ClearTextbox()
        txtGrade.Text = ""
        txtInvIn.Text = ""
        txtInvOut.Text = ""
        txtDiameter.Text = ""
        txtLength.Text = ""
        txtMaterial.Text = ""
        txtType.Text = ""
    End Sub
    'ADD PROPERTY FROM RESULTBUFFER TO TEXTBOX
    Private Sub PopulateXdataToForm(ByVal oSelectedObjID As ObjectId)
        Using tr
            If oSelectedObj.XData = Nothing Then
                'IF FRESH OBJECT, CLEAR FORM
                ClearTextbox()
            Else
                'check to see if created by same application
                Dim oTypeValueApp As TypedValue = oSelectedObj.XData.AsArray(0)
                If oTypeValueApp.Value = AppName Then
                    For Each oTypedValue In oSelectedObj.XData.AsArray
                        If oTypedValue.Value <> AppName Then
                            Dim arSplitPipeData() As String = Split(oTypedValue.Value, ",")
                            Select Case arSplitPipeData(0).ToString
                                Case "pipe-structure"
                                    Select Case arSplitPipeData(1).ToString
                                        Case ""
                                            cmbPipeOrStructure.Text = cmbPipeOrStructure.Items(0)
                                        Case "Pipe"
                                            cmbPipeOrStructure.Text = cmbPipeOrStructure.Items(1)
                                        Case "Structure"
                                            cmbPipeOrStructure.Text = cmbPipeOrStructure.Items(2)
                                    End Select
                                Case "type"
                                    txtType.Text = arSplitPipeData(1).ToString
                                Case "material"
                                    txtMaterial.Text = arSplitPipeData(1).ToString
                                Case "diameter"
                                    txtDiameter.Text = arSplitPipeData(1).ToString
                                Case "invertin"
                                    txtInvIn.Text = arSplitPipeData(1).ToString
                                Case "invertout"
                                    txtInvOut.Text = arSplitPipeData(1).ToString
                                Case "length"
                                    txtLength.Text = arSplitPipeData(1).ToString
                                Case "grade"
                                    txtGrade.Text = arSplitPipeData(1).ToString
                            End Select
                        End If
                    Next
                End If
            End If
            ' doc.LockDocument.Dispose()
        End Using
    End Sub
    Private Sub PopulateFormDataToObjectXdata(ByVal oSelectedObjID As ObjectId)
        Try
                Using tr
                    'doc.LockDocument() '(DocumentLockMode.Write, Nothing, Nothing, True)
                    'clear xdata
                        'clear info
                        oSelectedObj.XData.Dispose()
                        Exit Sub
                    ElseIf oSelectedObj.XData <> Nothing Then
                    End If
                    AddRegAppTableRecord(AppName)
                    Dim rb As New ResultBuffer
                    rb.Add(New TypedValue(1001, AppName))
                    rb.Add(New TypedValue(1000, "pipe-structure," & cmbPipeOrStructure.Text))
                    rb.Add(New TypedValue(1000, "type," & txtType.Text))
                    rb.Add(New TypedValue(1000, "material," & txtMaterial.Text))
                    rb.Add(New TypedValue(1000, "diameter," & txtDiameter.Text))
                    rb.Add(New TypedValue(1000, "invertin," & txtInvIn.Text))
                    rb.Add(New TypedValue(1000, "invertout," & txtInvOut.Text))
                    rb.Add(New TypedValue(1000, "length," & txtLength.Text))
                    rb.Add(New TypedValue(1000, "grade," & txtGrade.Text))
                    oSelectedObj.XData = rb
                    rb.Dispose()
                    tr.Commit()
                End Using
            End Using
            MsgBox(ex.Message)
        End Try
    End Sub
End Class
Civil 3D 2012
Work: Xeon W3503, 12GB, Quadro 2000, Yamakasi Sparta 301 + Dell PH2211
Home: 3930k, 12GB, GTX 590, U3011, QX2710
As Alfred said, you need a single typed value with the Registered Application name to clear it.
       'clear info
       rb.Dispose()
ElseIf.....
Alfred.NESWADBA
Message 2 of 7 (730 Views)
Re: can't dispose xdata
02-13-2012 05:37 PM in reply to: wang890
does that mean that you try to clean (to delete) the EED from the entity? If so you have to assign new XData containing just one RB-item containing only the App-Code but nothing else, so it get's removed from the entity.
If you do search for anything else, please describe what you mean by "to dispose XDATA" (as I think you don't mean .Dispose really),
PLUS an additional, important tip: please use the icon/function in the message-editor for placing code within the message:
otherwise (you see it in your thread-item) this code is
a) not readable
b) not useable (can't be copied&pasted to an editor as there are line-feeds and spaces lost).
- alfred -
Alfred NESWADBA
wang890
Message 3 of 7 (727 Views)
02-13-2012 05:54 PM in reply to: wang890
thanks for showing me that button to paste code. that's where it is. i'll go fix it up
yeah i was trying to run the dispose first then add a new one in or leave it empty. so you are saying just repopulate resultbuffer with empty one. i was trying to get it to the original state before populating xdata. is that doable?
if no xdata part of my code runs fast just populate a blank palette.
Civil 3D 2012
Hallex
Message 4 of 7 (704 Views)
02-14-2012 04:46 AM in reply to: wang890
Try
obj.xdata = New ResultBuffer()
to clear it
wang890
Message 5 of 7 (691 Views)
02-14-2012 10:36 AM in reply to: Hallex
ha, still doesn't work. the set to new resultbuffer doesn't clear it. maybe a bug?
i changed a little bit here but this is the code that is key to dispose this xdata
        Try
                Using tr
                    'clear xdata
                        'clear info
                        rb.Dispose()
                    End If
                    tr.Commit()
                End Using
            End Using
            MsgBox(ex.Message)
        End Try
    End Sub
Civil 3D 2012
chiefbraincloud
Message 6 of 7 (677 Views)
02-14-2012 12:36 PM in reply to: wang890
       'clear info
       rb.Dispose()
ElseIf.....
wang890
Message 7 of 7 (667 Views)
02-14-2012 01:28 PM in reply to: chiefbraincloud
yeah that worked. i also read this thread just now and they said you have to specify the app because other people can populate xdata with other app names as well. makes sense. but no way i can find this out on my own without this.
thanks you guys
http://forums.autodesk.com/t5/NET/Delete-XData/td-p/2280625
Civil 3D 2012
