i have a combo box which choose from 3 items one is blank. the triggered item changed event will erase the old set of corresponding xdata in the selected object and populate with new ones read from different text boxes. i was able to set the xdata for the first time ok. but when trying to dispose it won't dispose.
Imports System.Runtime Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.DatabaseServices Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application Imports Create_Pipe_Data.ActiveDrawing Public Class Container1 Public oSelectedObjID As ObjectId Public WithEvents doc As Document Public AppName As String = "CreatePipeData" Private m_DocData As MyDocData = Nothing Friend Shared ps As Autodesk.AutoCAD.Windows.PaletteSet = Nothing Dim myPalette As Container1 <CommandMethod("tp", CommandFlags.Transparent)> _ Public Sub DoIt() If m_DocData Is Nothing Then m_DocData = New MyDocData AddHandler AcApp.DocumentManager.DocumentActivated, AddressOf Me.DocumentManager_DocumentActivated AddHandler AcApp.DocumentManager.DocumentToBeDeactivated, AddressOf Me.DocumentManager_DocumentToBeDeactivated 'check to see if paletteset is already created If ps Is Nothing Then 'no so create it ps = New Autodesk.AutoCAD.Windows.PaletteSet("Create Pipe Data") 'create new instance of user control myPalette = New Container1() 'add it to the paletteset ps.Add("Create Pipe Data", myPalette) End If 'turn it on ps.Visible = True End Sub Private Sub AddRegAppTableRecord(ByVal regAppName As String) Dim db As Database = doc.Database Dim tr As Transaction = doc.TransactionManager.StartTransaction() Try Using tr Dim rat As RegAppTable = DirectCast(tr.GetObject(db.RegAppTableId, OpenMode.ForRead, False), RegAppTable) If Not rat.Has(regAppName) Then rat.UpgradeOpen() Dim ratr As New RegAppTableRecord() ratr.Name = regAppName rat.Add(ratr) tr.AddNewlyCreatedDBObject(ratr, True) End If tr.Commit() End Using Catch ex As Exception MsgBox(ex.Message) End Try End Sub Private Sub Container1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load If m_DocData Is Nothing Then m_DocData = New MyDocData doc = Application.DocumentManager.MdiActiveDocument 'doc.LockDocument(DocumentLockMode.Write, Nothing, Nothing, True) ' AddHandler doc.ImpliedSelectionChanged, AddressOf ObjectSelected AddHandler AcApp.DocumentManager.DocumentActivated, AddressOf Me.DocumentManager_DocumentActivated AddHandler AcApp.DocumentManager.DocumentToBeDeactivated, AddressOf Me.DocumentManager_DocumentToBeDeactivated 'AddHandler doc.ImpliedSelectionChanged, AddressOf ObjectSelected End Sub Private Sub DocumentManager_DocumentActivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs) 'display the current active document Try If Not m_DocData Is Nothing Then txtADwg.Text = m_DocData.Current.Stuff doc = Application.DocumentManager.MdiActiveDocument End If Catch ex As Exception MsgBox(ex.Message) End Try End Sub Private Sub DocumentManager_DocumentToBeDeactivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs) 'store the current contents Try If Not m_DocData Is Nothing Then m_DocData.Current.Stuff = txtADwg.Text End If Catch ex As Exception MsgBox(ex.Message) End Try End Sub Private Sub ObjectSelectEvent(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles doc.ImpliedSelectionChanged ObjectSelected() End Sub Private Sub ObjectSelected() 'Dim myDB As Database = HostApplicationServices.WorkingDatabase Dim myEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim PossibleSelectionSet As PromptSelectionResult = myEditor.SelectImplied Dim mySelectionSet As SelectionSet = Nothing Dim myObjectIDs As New List(Of ObjectId) Dim oSelectedObj As DBObject If PossibleSelectionSet.Status = PromptStatus.OK Then Using tr As Transaction = doc.TransactionManager.StartTransaction mySelectionSet = PossibleSelectionSet.Value For Each mySelObj As SelectedObject In mySelectionSet myObjectIDs.Add(mySelObj.ObjectId) Next End Using End If 'SET TO LAST OBJECT SELECTED If myObjectIDs.Count <> 0 Then Try Using oLock As DocumentLock = doc.LockDocument() '(DocumentLockMode.Write, Nothing, Nothing, True) Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr oSelectedObj = tr.GetObject(myObjectIDs.Item(myObjectIDs.Count - 1), OpenMode.ForRead, False) oSelectedObjID = oSelectedObj.ObjectId 'AFTER SELECT OBJECT, POPULATE FORM PopulateXdataToForm(oSelectedObjID) End Using End Using GroupBox1.Enabled = True Catch ex As Exception MsgBox(ex.Message) End Try Else GroupBox1.Enabled = False End If End Sub Private Sub txtType_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles txtType.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub txtMaterial_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtMaterial.MouseLeave, TextBox6.MouseLeave, TextBox5.MouseLeave, TextBox4.MouseLeave, TextBox3.MouseLeave, TextBox2.MouseLeave, TextBox1.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub txtLength_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtLength.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub txtInvOut_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtInvOut.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub txtInvIn_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtInvIn.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub txtGrade_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtGrade.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub TxtDiameter_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles txtDiameter.MouseLeave PopulateFormDataToObjectXdata(oSelectedObjID) End Sub Private Sub cmbPipeOrStructure_SelectionChangeCommitted(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmbPipeOrStructure.SelectionChangeCommitted PipeStructureChanged() End Sub Private Sub PipeStructureChanged() If cmbPipeOrStructure.Text = "Pipe" Then gpbPipe.Enabled = True gpbStructure.Enabled = False Using oLock As DocumentLock = doc.LockDocument() Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr 'Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False) 'If oSelectedObj.XData <> Nothing Then ' Dim rb As ResultBuffer = oSelectedObj.XData ' rb.Dispose() 'End If 'tr.Commit() PopulateFormDataToObjectXdata(oSelectedObjID) End Using End Using ElseIf cmbPipeOrStructure.Text = "Structure" Then gpbStructure.Enabled = True gpbPipe.Enabled = False Using oLock As DocumentLock = doc.LockDocument() Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr 'Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False) 'If oSelectedObj.XData <> Nothing Then ' Dim rb As ResultBuffer = oSelectedObj.XData ' rb.Dispose() 'End If 'tr.Commit() PopulateFormDataToObjectXdata(oSelectedObjID) End Using End Using ElseIf cmbPipeOrStructure.Text = "" Then ClearTextbox() gpbStructure.Enabled = False gpbPipe.Enabled = False Using oLock As DocumentLock = doc.LockDocument() Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr 'Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False) 'If oSelectedObj.XData <> Nothing Then ' Dim rb As ResultBuffer = oSelectedObj.XData ' rb.Dispose() 'End If 'tr.Commit() PopulateFormDataToObjectXdata(oSelectedObjID) End Using End Using End If End Sub Private Sub ClearTextbox() txtGrade.Text = "" txtInvIn.Text = "" txtInvOut.Text = "" txtDiameter.Text = "" txtLength.Text = "" txtMaterial.Text = "" txtType.Text = "" End Sub 'ADD PROPERTY FROM RESULTBUFFER TO TEXTBOX Private Sub PopulateXdataToForm(ByVal oSelectedObjID As ObjectId) Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False) If oSelectedObj.XData = Nothing Then 'IF FRESH OBJECT, CLEAR FORM ClearTextbox() Else 'check to see if created by same application Dim oTypeValueApp As TypedValue = oSelectedObj.XData.AsArray(0) If oTypeValueApp.Value = AppName Then For Each oTypedValue In oSelectedObj.XData.AsArray If oTypedValue.Value <> AppName Then Dim arSplitPipeData() As String = Split(oTypedValue.Value, ",") Select Case arSplitPipeData(0).ToString Case "pipe-structure" Select Case arSplitPipeData(1).ToString Case "" cmbPipeOrStructure.Text = cmbPipeOrStructure.Items(0) gpbStructure.Enabled = False gpbPipe.Enabled = False Case "Pipe" cmbPipeOrStructure.Text = cmbPipeOrStructure.Items(1) gpbStructure.Enabled = False gpbPipe.Enabled = True Case "Structure" cmbPipeOrStructure.Text = cmbPipeOrStructure.Items(2) gpbStructure.Enabled = True gpbPipe.Enabled = False End Select Case "type" txtType.Text = arSplitPipeData(1).ToString Case "material" txtMaterial.Text = arSplitPipeData(1).ToString Case "diameter" txtDiameter.Text = arSplitPipeData(1).ToString Case "invertin" txtInvIn.Text = arSplitPipeData(1).ToString Case "invertout" txtInvOut.Text = arSplitPipeData(1).ToString Case "length" txtLength.Text = arSplitPipeData(1).ToString Case "grade" txtGrade.Text = arSplitPipeData(1).ToString End Select End If Next End If End If ' doc.LockDocument.Dispose() End Using End Sub Private Sub PopulateFormDataToObjectXdata(ByVal oSelectedObjID As ObjectId) Try Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using oLock As DocumentLock = doc.LockDocument() Using tr 'doc.LockDocument() '(DocumentLockMode.Write, Nothing, Nothing, True) Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False) 'clear xdata If cmbPipeOrStructure.Text = "" Then 'clear info oSelectedObj.XData.Dispose() Exit Sub ElseIf oSelectedObj.XData <> Nothing Then oSelectedObj.XData.Dispose() End If AddRegAppTableRecord(AppName) Dim rb As New ResultBuffer rb.Add(New TypedValue(1001, AppName)) rb.Add(New TypedValue(1000, "pipe-structure," & cmbPipeOrStructure.Text)) rb.Add(New TypedValue(1000, "type," & txtType.Text)) rb.Add(New TypedValue(1000, "material," & txtMaterial.Text)) rb.Add(New TypedValue(1000, "diameter," & txtDiameter.Text)) rb.Add(New TypedValue(1000, "invertin," & txtInvIn.Text)) rb.Add(New TypedValue(1000, "invertout," & txtInvOut.Text)) rb.Add(New TypedValue(1000, "length," & txtLength.Text)) rb.Add(New TypedValue(1000, "grade," & txtGrade.Text)) oSelectedObj.XData = rb rb.Dispose() tr.Commit() End Using End Using Catch ex As Exception MsgBox(ex.Message) End Try End Sub End Class
Solved by chiefbraincloud. Go to Solution.
does that mean that you try to clean (to delete) the EED from the entity? If so you have to assign new XData containing just one RB-item containing only the App-Code but nothing else, so it get's removed from the entity.
If you do search for anything else, please describe what you mean by "to dispose XDATA" (as I think you don't mean .Dispose really),
PLUS an additional, important tip: please use the icon/function in the message-editor for placing code within the message:
otherwise (you see it in your thread-item) this code is
a) not readable
b) not useable (can't be copied&pasted to an editor as there are line-feeds and spaces lost).
- alfred -
thanks for showing me that button to paste code. that's where it is. i'll go fix it up
yeah i was trying to run the dispose first then add a new one in or leave it empty. so you are saying just repopulate resultbuffer with empty one. i was trying to get it to the original state before populating xdata. is that doable?
if no xdata part of my code runs fast just populate a blank palette.
Try
obj.xdata = New ResultBuffer()
to clear it
ha, still doesn't work. the set to new resultbuffer doesn't clear it. maybe a bug?
i changed a little bit here but this is the code that is key to dispose this xdata
Private Sub PopulateFormDataToObjectXdata(ByVal oSelectedObjID As ObjectId) Try Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using oLock As DocumentLock = doc.LockDocument() Using tr 'doc.LockDocument() '(DocumentLockMode.Write, Nothing, Nothing, True) Dim oSelectedObj As DBObject = tr.GetObject(oSelectedObjID, OpenMode.ForWrite, False) 'clear xdata If cmbPipeOrStructure.Text = "" Then 'clear info oSelectedObj.XData.Dispose() ElseIf oSelectedObj.XData <> Nothing Then oSelectedObj.XData.Dispose() AddRegAppTableRecord(AppName) Dim rb As New ResultBuffer rb.Add(New TypedValue(1001, AppName)) rb.Add(New TypedValue(1000, "pipe-structure," & cmbPipeOrStructure.Text)) rb.Add(New TypedValue(1000, "type," & txtType.Text)) rb.Add(New TypedValue(1000, "material," & txtMaterial.Text)) rb.Add(New TypedValue(1000, "diameter," & txtDiameter.Text)) rb.Add(New TypedValue(1000, "invertin," & txtInvIn.Text)) rb.Add(New TypedValue(1000, "invertout," & txtInvOut.Text)) rb.Add(New TypedValue(1000, "length," & txtLength.Text)) rb.Add(New TypedValue(1000, "grade," & txtGrade.Text)) oSelectedObj.XData = rb rb.Dispose() End If tr.Commit() End Using End Using Catch ex As Exception MsgBox(ex.Message) End Try End Sub
As Alfred said, you need a single typed value with the Registered Application name to clear it.
'clear info
rb.Dispose()
ElseIf.....
yeah that worked. i also read this thread just now and they said you have to specify the app because other people can populate xdata with other app names as well. makes sense. but no way i can find this out on my own without this.
thanks you guys
http://forums.autodesk.com/t5/NET/Delete-XData/td-p/2280625
