.NET
Distinguished Contributor
BMcAnney
Message 1 of 5 (436 Views)
Can't capture key events in windows form
436 Views, 4 Replies
03-15-2012 01:36 PM
I have created a basic add-on that shows a modal windows form. The only issue I am running into is that I am completely unable to capture any key events in the form. I just want to make the escape key close my form, but I'm having no luck. Here is my basic setup:
        <CommandMethod("myCommand")> _
        Public Sub myCommand()
            Dim myForm As Form1 = New Form1
            Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(myForm)
        End Sub
Then in the form code, I have this, for testing purposes:
    Private Sub Form1_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles Me.KeyPress
        MsgBox("keypress")
    End Sub
I've also tried KeyUp and KeyDown. Key presses are working inside the form (I can use the keyboard to select an item in a combobox, for example), but I never hit the event handlers. Does anyone have a clue what I'm doing wrong here?
Thanks!
Valued Mentor
gasty1001
Message 2 of 5 (426 Views)
Re: Can't capture key events in windows form
03-15-2012 09:16 PM in reply to: BMcAnney
Hi:
You need to set the KeyPreview form's property to true, and then capture the keydown event with something like:
Private Sub MyForm_KeyDown(ByVal sender As System.Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles MyBase.KeyDown
If e.KeyCode = Windows.Forms.Keys.Escape Then
 Me.Close()
End If
End Sub
Gaston Nunez
Hallex
Message 3 of 5 (421 Views)
03-15-2012 11:05 PM in reply to: BMcAnney
Here is code snip to capture KeyPress on numeric only textbox
which is allow you to jump to the next textbox on form after click Enter:
	string DSep = ',';
	private void txtBox1_KeyPress(object sender, System.Windows.Forms.KeyPressEventArgs e)
		if (char.IsNumber(e.KeyChar) == false & Microsoft.VisualBasic.AscW(e.KeyChar) != 46) {
			if (e.KeyChar == Convert.ToChar(DSep)) {
				e.Handled = true;
			} else if (Microsoft.VisualBasic.AscW(e.KeyChar) == 13) {
				this.txtBox2.Select();
				e.Handled = false;
			} else {
				e.Handled = true;
 Hope that helps
~'J'~
BMcAnney
Message 4 of 5 (411 Views)
03-16-2012 05:43 AM in reply to: gasty1001
Thank you, Gaston! The KeyPreview setting for the form is all I needed to change. It was off by default.
Brent
chiefbraincloud
Message 5 of 5 (400 Views)
03-16-2012 10:31 AM in reply to: BMcAnney
If all you want to do is close the form on the Escape key, you don't have to catch any key events.  All you have to do is put a button on your form (it doesn't even need to be visible), and assign that button to the forms CancelButton property.
