.NET
Can someone tell me why this isnt working?
1 REPLY 1
275 Views, 1 Reply
I have a function which is to delete block references that meet a certain
criteria. Namely that they are "revision" blocks, and there revision letter
match what is passed into the function. I now have two versions of this, one
that "works" and one that does not. I want to understand, and fix, the reasons
for the non-working one. The non-working one utilizes a helper function which
creates a collection of object id's and then goes through those id's and deletes
any that meet the criteria. The version that works simply goes through *paperspace
and does the same without using a collection of id's.
The non-working version, does not cause any errors, and seems to behave properly
while stepping through the code, but does not achieve the desired result. If anyone
can see what I have overlooked here, I'd appreciate the pointer.
Sorry for posting so much, code!
Perry
[code]-----------------------------------------------------------------
/// Delete a rev block based on the rev letter passed in. This one doesnt work.
/// Utilizes the ObjectIDcollection.
public void Delete2(string letter)
Utilities.prompt("\nIn revision delete.");
ObjectIdCollection refEnts = Utilities.getBlockIds();
using (Database db = HostApplicationServices.WorkingDatabase)
using (Transaction trans = db.TransactionManager.StartTransaction())
Utilities.prompt("\nThere are " + refEnts.Count + " block refs in this space.");
foreach (ObjectId id in refEnts)
BlockReference blkRef = (BlockReference)trans.GetObject(id, OpenMode.ForWrite, false);
BlockTableRecord blkDef = (BlockTableRecord)trans.GetObject(blkRef.BlockTableRecord, OpenMode.ForWrite);
if (blkDef.Name.ToUpper() == "TBREVISION")
//Get the attribute references,if any
AttributeCollection atts;
atts = blkRef.AttributeCollection;
if (atts.Count > 0)
foreach (ObjectId attId in atts)
AttributeReference att;
string txt = "";
using (att = (AttributeReference)trans.GetObject(attId, OpenMode.ForWrite, false))
txt = (att.TextString.ToString());
//If the attribute textstring matches the passed in rev letter
//delete the block reference
if (txt == letter)
Utilities.prompt("\ndeleting " + blkDef.Name);
blkRef.Erase();//block ref not erasing!
break;
blkRef.Dispose();
blkDef.Dispose();
refEnts.Dispose();
[helper]---------------------------------------------------------------------------
public static ObjectIdCollection getBlockIds()
LayoutManager lManager = LayoutManager.Current;
string currentLayoutName = lManager.CurrentLayout;
ObjectId currentLayout = lManager.GetLayoutId(currentLayoutName);
ObjectIdCollection refEnts = new ObjectIdCollection();
using (Transaction t = db.TransactionManager.StartTransaction())
//get the block table
BlockTable bt = (BlockTable)t.GetObject(db.BlockTableId, OpenMode.ForRead);
//get the (x)space table record
BlockTableRecord btr = new BlockTableRecord();
if (currentLayoutName == "Model")
btr = (BlockTableRecord)t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
else
// This is supposed to get current paperspace layout
btr = (BlockTableRecord)t.GetObject(bt[BlockTableRecord.PaperSpace], OpenMode.ForRead);
Entity ent;
foreach (ObjectId objId in btr)
ent = (Entity)t.GetObject(objId, OpenMode.ForRead);
if (ent is BlockReference)
refEnts.Add(objId);
ent.Dispose();
t.Commit();
btr.Dispose();
bt.Dispose();
}//end using transaction t
}//end using database
return (refEnts);
1 REPLY 1
> Perry
> if (atts.Count > 0)
> string txt = "";
> if (txt == letter)
> break;
> blkRef.Dispose();
> blkDef.Dispose();
> refEnts.Dispose();
> else
> Entity ent;
> refEnts.Add(objId);
> ent.Dispose();
> t.Commit();
> btr.Dispose();
> bt.Dispose();
> return (refEnts);
Racked my brains on this for HOURS, so irritating, it SHOULD work.
Then it hit me, like a fish across the face.
Note the lack of a "trans.commit()" near the end of the delete function.
Anyone know where I can get one of those big "cartoon" boots, the one on the stick where
when you pull the rope it kicks you in the arse.
”Boost
