.NET
truss_85
Message 1 of 3 (189 Views)
Can not operate items in selection set
189 Views, 2 Replies
02-26-2012 07:19 AM
Hi Everyone,
I have a public sub it works fine with selectionsets.
But when I want to use in a fence selection set it did not work.
I get message "number of selected object:" truly but it did not set att values.
I post the code below. What am I missing?
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
    <CommandMethod("hs")> _
    Public Sub gget()
        Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim entOpt As PromptEntityOptions = New PromptEntityOptions("Pick a polyline:")
        entOpt.AllowNone = True
        Dim spoly As PromptEntityResult = acDocEd.GetEntity(entOpt)
        Dim acCurDb As Database = Application.DocumentManager.MdiActiveDocument.Database
        If spoly.Status = PromptStatus.None Then
            acDocEd.WriteMessage("Selection invalid!...")
        End If
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim obj As DBObject = acTrans.GetObject(spoly.ObjectId, OpenMode.ForWrite)
            If TypeOf (obj) Is Polyline Then
                Dim poly As Polyline = CType(obj, Polyline)
                Dim opt As New Point3d
                Dim sel_fence As New Autodesk.AutoCAD.Geometry.Point3dCollection
                For ii = 0 To poly.NumberOfVertices - 1
                    opt = poly.GetPoint3dAt(ii)
                    sel_fence.Add(opt)
                Next
                Dim acTypValAr(0) As TypedValue
                acTypValAr.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
                Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
                Dim prselres As PromptSelectionResult = acDocEd.SelectFence(sel_fence, acSelFtr)
                If prselres.Status = PromptStatus.OK Then
                    Dim acSSet As SelectionSet = prselres.Value
                    Dim nn As Integer = 0
                    For Each acSSObj As SelectedObject In acSSet
                        SetAttribute(acSSObj.ObjectId, "BLOCKNAME", "ATTNAME", nn.ToString)
                        nn = nn + 1
                    Next
                    acDocEd.WriteMessage("Number of objects selected: " & acSSet.Count.ToString())
                End If
            End If
        End Using
    End Sub
    Public Sub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname As String, ByVal AttTag As String, ByVal AttVal As String)
        Dim MyDb As Database = Application.DocumentManager.MdiActiveDocument.Database
        If BlockID.IsNull Then Exit Sub
        Try
            Using myTrans As Transaction = MyDb.TransactionManager.StartTransaction
                Dim myBlckRef As BlockReference
                Dim myAttColl As AttributeCollection
                Dim myBlckTable As BlockTableRecord
                myBlckRef = BlockID.GetObject(OpenMode.ForWrite)
                If myBlckRef.IsDynamicBlock Then
                    myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord, OpenMode.ForRead)
                Else
                    myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord, OpenMode.ForRead)
                End If
                If String.Compare(myBlckTable.Name, blckname, True) = 0 Then
                    myAttColl = myBlckRef.AttributeCollection
                    Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectId
                    Dim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReference
                    For Each myEnt In myAttColl
                        myAttRef = myEnt.GetObject(OpenMode.ForWrite)
                        If String.Compare(myAttRef.Tag, AttTag, True) = 0 Then
                            myAttRef.TextString = AttVal.ToString
                        End If
                    Next
                End If
                myTrans.Commit()
            End Using
        Catch ex As Exception
        End Try
    End Sub
End Class
Alfred.NESWADBA
Message 2 of 3 (185 Views)
Re: Can not operate items in selection set
02-26-2012 07:22 AM in reply to: truss_85
you are working with nested transactions, that is a little bit more critical and you have to be careful commiting a sub-transaction, but not commiting the top-transaction.
As a first try do also a commit of the transaction in your primary sub "ssget"
HTH, - alfred -
Alfred NESWADBA
truss_85
Message 3 of 3 (180 Views)
02-26-2012 07:41 AM in reply to: Alfred.NESWADBA
How embarrassing it is!...
I did not see that thank you very musch again...
