.NET
.NET
Active Member
583408432
Message 1 of 3 (200 Views)
Can not display the PlotStyleDialog() dialog box
200 Views, 2 Replies
12-24-2013 04:53 AM
'I used about three methods are still not solve the problem.
Dim p As New Autodesk.AutoCAD.Windows.PlotStyleDialog()
'1.
p.ShowDialog()
'2.
p.PlotStyle = "acad.ctb"
p.ShowDialog()
'3.
p.PlotStyle = "C:\Documents and Settings\Administrator\Application Data\Autodesk\AutoCAD 2010\R18.0\chs\Plotters\Plot Styles\acad.ctb"
p.ShowDialog()
Confused met to but the solution is simple.
This PlotStyleDialog can only be used in the so called Named Plot Style drawings.
So if you're dialog does not show its probably the Color Depended drawing type -- most drawings still are.
You need to create a STB style first, then convert the drawing.
Try this before running the program:
Command: CONVERTCTB
    acad.ctb
    new.stb
Command: CONVERTPSTYLES
   new.stb
Command: NETLOAD
    <youreNamedDLL>
Command: psd
using System;
using System.Collections.Generic;
using System.Text;
using System.Text.RegularExpressions;
using System.Windows.Forms;
using System.IO;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.Publishing;
namespace PlotStyleDialog
public class Class1
[CommandMethod("psd")]
public void PlotStyleDlg()
var psd = new PlotStyleDialog();
DialogResult dlgRes=psd.ShowDialog();
Active Member
583408432
Message 2 of 3 (153 Views)
Re: Can not display the PlotStyleDialog() dialog box
12-27-2013 08:30 PM in reply to: 583408432
The above code codes cannot show PlotStyleDialog.
Can someone solve this problem?Thanks in advance!
SENL1362
Message 3 of 3 (140 Views)
12-28-2013 09:40 AM in reply to: 583408432
Command: CONVERTCTB
    acad.ctb
    new.stb
   new.stb
Command: NETLOAD
    <youreNamedDLL>
Command: psd
using System;
using System.Text;
using System.IO;
    public class Class1
