Show only
Search instead for
Is it possible to keep a modeless dialog box permanently open (aside) just like a properties or tool pallete dialog box?
If Yes, by keeping permanently, can I work in autocad environment normally as usual, like save, edit, close and open other drawings?
Note: Just assume that I am making a calculator-like dialog box. I would like to keep it open till the autocad application closes? (even in zero document mode.)
Hi, it is possible to open a modeless Dialog and you can work in AutoCAD Environment normally. But it is recommended to use Palette in this case. you can go through below link to find out the pros and cons. of modal , modeless and Palette .
