.NET
Can i close the inactive drawing file using c#?
3 REPLIES 3
RamanSBV
633 Views, 3 Replies
I need to close drawing file which is inactive. Please guide me how i can achive same.
Raman
3 REPLIES 3
norman.yuan
in reply to: RamanSBV
Yes, you can close drawing which is not current active drawing (not Application.DocumentManager.MdiActiveDocument) easily.
Here is sample code:
public class MyCommands
    [CommandMethod("CloseTest")]
    public static void CloseNonActiveDrawing()
        Document dwg = Application.DocumentManager.MdiActiveDocument;
        Editor ed = dwg.Editor;
        foreach (Document doc in Application.DocumentManager)
            if (doc.Name != dwg.Name)
                string fName=System.IO.Path.GetFileName(doc.Name);
                doc.CloseAndDiscard();
                ed.WriteMessage("\nDrawing \"{0}\" has been closed!", fName);
                break;
Norman Yuan
Drive CAD With Code
RamanSBV
in reply to: norman.yuan
Thanks for your respose on this issue.
If i use above code to close the drawing file, all changes are going away.
I want to save the changes with close.
Please guide me
Raman
Try to change:
 with:
doc.CloseAndSave(doc.Name);
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
