.NET
Can GRDRAW be done with VB.net?
19 REPLIES 19
Message 1 of 20
1198 Views, 19 Replies
I do tons of grdraw type stuff with lisp.
I am looking at if the .net API will allow me to draw temprary vectors like grdraw did.
I am guessing this has been answered before but did not find it in this group.
In addition, teach me to fish.
How should I have investigated this on my own?
I am a pretty good VB6 writer, and learning VB.net and how the frameworks "work" for any language.
But this would be a great case study I could learn from.
Shoul I be looking at some help file showing an object model for the .net acad API?
I downloaded the objectarx sdk help files, not sure if that applies to using VB.net though.
or should I have visual studio.net installed and reference the right dll's (or frameworks...) and look in the object
browser there?
how do real programmers walk through the .net API for acad to see whats in it?
feel free to redirect me to other threads, this has to have been talked about before...
Thanks in advance.
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
19 REPLIES 19
Message 2 of 20
NathTay
Hi James,
There was a similar post where no one could suggest a .NET API equivalent of GRDRAW or GRVECS. http://discussion.autodesk.com/thread.jspa?threadID=420998
If there is no equivalent I have an example of using GRVECS in VBA which you may be able to use this approach with VB.NET. http://discussion.autodesk.com/thread.jspa?messageID=3955682
Regards - Nathan
Message 3 of 20
cool, I have been looking for that code for a while.
I need that for VB6.
I installed .net finally, and opened the hello world sample that was in the objectarx SDK.
I opened the object browser and looked at the acdbg or whatever libraries and found the jig method.
I have a feeling calling the activex grvecs will be too slow for things that draw a lot of temp vectors.
Surely this is not something only lisp can do! I would think some sharp C programmer could tell me how to do grvecs and
more with .net - or maybe the .net API is not fully baked...
James Maeding
|>browser there?
|>Thanks in advance.
|>James Maeding
James Maeding
Message 4 of 20
James,
I had similar problem since 2006 is
currently not an option for me. In 2005 there is no managed AcEdJig class, so I
had to use P/Invoke interop to call C++ APIs directly. Here is a
function definition (VB.NET) - it does exactly what GRDRAW does in
Lisp:
<DllImport("acad.exe",
EntryPoint:="acedGrDraw", CallingConvention:=CallingConvention.Cdecl)>
_
Public
color=#0000ff>Shared
Function acedGrDraw(
color=#0000ff>ByVal
fromPoint As
color=#0000ff>Double
(), ByVal toPoint
color=#0000ff>As
Double(),
color=#0000ff>ByVal
color As
color=#0000ff>Integer
, ByVal hl
color=#0000ff>As
Integer)
color=#0000ff>As
Integer
color=#0000ff>End
color=#0000ff>Function
Note: fromPoint and toPoint are
three-element arrays of doubles. For color and hl (Highlight) value
definitions browse through the ObjectARX documentation. Furthermore,
you can implement Point3D class and enumerators for fromPoint, toPoint,
color and hl parameters.
Maksim Sestic
"James Maeding" <jmaeding...hunsaker...com>
wrote in message
face=Verdana size=2>news:4953556@discussion.autodesk.com
face=Verdana size=2>...
I do tons of
to fish.
I am a pretty good
language.
from.
the .net acad API?
object
browser there?
Thanks in
advance.
James Maeding
jmaeding -
athunsaker - com
Message 5 of 20
oh wow, now we are talking!
This is huge because this was the main thing preventing me from spending time learning .net.
Thank you so much! I am sure others out there are drooling at this.
Now I just need to learn how all this .net stuff works. Its really diffferent than VB6 activex programming.
Maksim Sestic
James,
I had similar problem since 2006 is currently not an option for me. In 2005 there is no managed AcEdJig class, so I had
to use P/Invoke interop to call C++ APIs directly. Here is a function definition (VB.NET) - it does exactly what GRDRAW
does in Lisp:
_
Public Shared Function acedGrDraw(ByVal fromPoint As Double(), ByVal toPoint As Double(), ByVal color As Integer, ByVal
hl As Integer) As Integer
End Function
Note: fromPoint and toPoint are three-element arrays of doubles. For color and hl (Highlight) value definitions browse
through the ObjectARX documentation. Furthermore, you can implement Point3D class and enumerators for fromPoint,
toPoint, color and hl parameters.
Maksim Sestic
James Maeding
Message 6 of 20
Being a
VB6 developer myself, I can tell that .NET programming concepts are
getting much deeper than that 🙂 Frankly, I didn't care much about programming
languages since I was working on my own, and my code did what it was
supposed to do. As soon as I gathered team of guys working on the same project
I stumbled into a problem also known as "DLL Hell" (
href="http://www.google.com/search?hl=en&q=DLL+Hell">http://www.google.com/search?hl=en&q=DLL+Hell
DotNET was the only viable solution apart from all of us learning the same
programming language.
A word or two on .NET concepts... You
will have to revise A LOT of what you currently know about programming
techniques 🙂 Language syntax itself is the easiest part. Some people
say that it's "real OOP", my conclusion was that now it takes much more time to
plan and considerably less time to code. Plain and simple. Take a look at
the following links on VB.NET programming, it might give you a hint where to
start from:
Maksim Sestic
wrote in message
face=Verdana size=2>news:4954606@discussion.autodesk.com
oh wow, now we are
talking!
programming.
Maksim Sestic <
href="mailto:info@geoinova.com">
size=2>info@geoinova.com
size=2>>
James,
had
does in
Lisp:
<DllImport("acad.exe", EntryPoint:="acedGrDraw",
CallingConvention:=CallingConvention.Cdecl)> _
As Integer, ByVal
End Function
Note:
fromPoint,
Maksim
Sestic
James Maeding
jmaeding -
athunsaker - com
Message 7 of 20
Thanks for the comments, those are good links. I know what you mean about the dll hell. Dan Appleman did a good book
on the differences between vb6 and .net, and the wrox vb.net book is good too.
Can you explin a little what you mean by it taking more time to plan.
Do you mean if you have a team on a project and need to plan how things get split up, or do you mean there are lots of
ways of using the various frameworks, and I need to choose carefully?
any help appreciated.
Also, can that dll import trick be done to work with vb6? I have progs in VB6 I would like to add that grdraw
capability to.
thx
Being a VB6 developer myself, I can tell that .NET programming concepts are getting much deeper than that 🙂 Frankly, I
didn't care much about programming languages since I was working on my own, and my code did what it was supposed to do.
As soon as I gathered team of guys working on the same project I stumbled into a problem also known as "DLL Hell"
(http://www.google.com/search?hl=en&q=DLL+Hell). DotNET was the only viable solution apart from all of us learning the
same programming language.
A word or two on .NET concepts... You will have to revise A LOT of what you currently know about programming techniques
:-) Language syntax itself is the easiest part. Some people say that it's "real OOP", my conclusion was that now it
takes much more time to plan and considerably less time to code. Plain and simple. Take a look at the following links on
VB.NET programming, it might give you a hint where to start from:
- The Code Project (http://www.codeproject.com/vb/net/)
- vbCity/DevCity.NET Forums (http://www.vbcity.com/forums/faq.asp?fid=15)
- VB.NET Heaven (http://www.vbdotnetheaven.com/)
- DevX VB.NET Articles (http://www.devx.com/dotnet/Door/10587)
- Xtreme VB Talk (http://www.xtremevbtalk.com)
- DeveloperFusion (http://www.developerfusion.co.uk/vbnet/)
- Microsoft VB Developer Center (http://www.msdn.microsoft.com/vbasic/)
Maksim Sestic
James Maeding
Message 8 of 20
James,
The very same thing should work in VB6 too. By "planning" I actually ment
planning within the scope of new functionalities offered by Framework
itself. I don't say in VB6 you don't need to plan certain approach, I just
say that it pays back triple in .NET 🙂
Maksim Sestic
"James Maeding" wrote in message
news:4956162@discussion.autodesk.com...
too.
capability to.
thx
Maksim Sestic
James Maeding
Message 9 of 20
No unfurtunately the same thing won't work in VB6. VB6 can only do stdcall
calling convention and this function is exported from autocad using the
cdecl calling convention.
Albert
"Maksim Sestic" wrote in message
news:4956942@discussion.autodesk.com...
James,
Maksim Sestic
too.
capability to.
thx
Maksim Sestic
James Maeding
Message 10 of 20
Albert, you're right. I figured it out while
trying to reproduce that API call from VB6... James, I guess you can still write
acedGrDraw function (as explained) in VB.NET, exposing it to VB6 via COM
Interop.
Useful links on exposing COM Interfaces of .NET
classes:
Maksim Sestic
size=2>
No unfurtunately
calling convention
cdecl calling
convention.
Albert
"Maksim Sestic" <
> wrote in
message
face=Verdana size=2>news:4956942@discussion.autodesk.com
James,
Maksim Sestic
"James Maeding"
<jmaeding...hunsaker...com> wrote in message
href="news:4956162@discussion.autodesk.com">
size=2>news:4956162@discussion.autodesk.com
size=2>...
you mean about
on the
good
too.
to plan.
things get
ways of using the
any help
appreciated.
capability
to.
thx
I
own,
as "DLL Hell"
size=2>http://www.google.com/search?hl=en&q=D...
face=Verdana size=2>). DotNET was the only viable
us learning the
takes much
simple. Take
href="http://www.codeproject.com/vb/net/">
size=2>http://www.codeproject.com/vb/net/
size=2>)
href="http://www.vbcity.com/forums/faq.asp?fid=15">
size=2>http://www.vbcity.com/forums/faq.asp?fid...
size=2>)
- VB.NET Heaven (
href="http://www.vbdotnetheaven.com/">
size=2>http://www.vbdotnetheaven.com/
href="http://www.devx.com/dotnet/Door/10587">
size=2>http://www.devx.com/dotnet/Door/10587
size=2>)
- Xtreme VB Talk (
face=Verdana size=2>http://www.xtremevbtalk.com
size=2>)
- DeveloperFusion (
href="http://www.developerfusion.co.uk/vbnet/">
size=2>http://www.developerfusion.co.uk/vbnet/
size=2>)
href="http://www.msdn.microsoft.com/vbasic/">
size=2>http://www.msdn.microsoft.com/vbasic/
size=2>)
Maksim Sestic
James Maeding
Civil Engineer
and Programmer
Message 11 of 20
NathTay
Hi Albert, do you know if it will be in the .NET API in a future release?
Regards - Nathan
Message 12 of 20
Wow, this gets deep fast. I am starting to see how different .net is.
I looked at the helloworld prog in the objectarx sdk download and how it uses the transaction manager to do things.
It looks like I am doing objectarx programming in visual basic.
I am ok with learning but this is such a twist. Now the divide between programming in lisp and VB (vb.net) is huge.
I can teach someone lisp writing pretty fast, but you have to know a whole lot and be practiced at vb.net to write
vb.net progs for acad.
Am I the only one who thinks vb.net learning curve is way beyond the time availablity of most cad managers?
Its like you become a very well educated programmer, or your complicated projects written in VB6 become incompatible
with acad some time soon.
Is my read on all this wrong?
Albert, you're right. I figured it out while trying to reproduce that API call from VB6... James, I guess you can still
write acedGrDraw function (as explained) in VB.NET, exposing it to VB6 via COM Interop.
Useful links on exposing COM Interfaces of .NET classes:
- http://www.codeproject.com/vb/net/MusaExposingCOM.asp (VB.NET, early and late binding)
- http://www.codeproject.com/dotnet/COM_DOTNET_INTEROP.asp (COM Interop, explained)
- http://www.codeproject.com/dotnet/cominterop.asp (C#, see Part II)
- http://www.codeproject.com/csharp/CSComTemplate.asp (COM Class wizard in C#)
Maksim Sestic
James Maeding
Message 13 of 20
>> James Maeding
You SIG doesn't say 'cad manager'.
Message 14 of 20
But that is what I do, I am a full time support person.
I did civil design for 10 years and learned programming along the way, as well as troubleshooting and organizing
projects, like most cad managers.
The difference is I like programming a lot while many cad managers just settle for what others can produce.
You can see that I am not a computer science major though.
Jsut out of curiousity Tony, how did you get into the acad side of programming and what makes up your bread and butter
these days?
My biggest programming effort is the in house civil design prog we use. My day to day is helping project teams get past
hurdles. this inclused everything from interviewing new hires to fixing broken drawings. I like it.
Tony Tanzillo
|>>> James Maeding
James Maeding
Message 15 of 20
I can't disclose anything about future releases.
Sorry,
albert
wrote in message news:4959802@discussion.autodesk.com...
Regards - Nathan
Message 16 of 20
Hold it. Don't confuse the API and the language.
You can use VB.NET to program against the COM API just like you did with
VB6.
You can also use VB.NET to program against the .NET API.
In fact you can mix the 2 APIs in the same project or function.
albert
news:4959900@discussion.autodesk.com...
COM Interop.
late binding)
explained)
C#)
Maksim Sestic
James Maeding
Message 17 of 20
NathTay
No worries.
Message 18 of 20
well, I would stick with VB6 if I wanted to do progs that just used com.
I understand that you can do both com and .net api with .net.
I have found I can write much slicker apps with lisp and objectdcl than with VB6/VBA and com.
This is because lisp is hooked up better with the acad command line than com is.
For instance,
Can you write a function with com that asks the user to pick an entity or type a number?
This is important for routines that need an elevation to do something, and the user might have some text already drawn
with that elevation in it.
I could not do this with com but am hoping the .net api will give more control of user input...
the GRDraw is another thing that handicapped com, until now...
thx
Albert Szilvasy
|>VB6.
|>albert
James Maeding
Message 19 of 20
Yes, you can. .NET might give
you a slightly more power to control user input than existing COM interface. On
the other hand, .NET will surely help you develop more integrated and more
complex applications, without fear of DLL incompatibility, etc.
Message 20 of 20
>> For instance, Can you write a function with com
Well, you must not know very much about COM if you
ask a question like that.
Of course you can do that with COM.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
”Boost
