.NET
Can AutoCAD MEP 2011 and Revit MEP 2012 mess up the deserialize process of file
0 REPLIES 0
Message 1 of 1
273 Views, 0 Replies
I have a dll which runs perfectly on pcs with AutoCAD 2012, but crashes when I try to run it on pcs with AutoCAD MEP 2011 and Revit MEP 2012 installed.
The dll is crated with VS2008.
The problems seems to be deserizlizing a list from a file and populating a combobox  The list is not deserialize, combobox is empty and exception is thrown when I try to set the selected item to the first one.
Any ideas if having AutoCAD MEP 2011 and Revit 2012 can mess up the serialization / deserialize process?
Thanks.
0 REPLIES 0
”Boost
