.NET
Calling -INSERT Command from AutoCAD.net (2012).
18 REPLIES 18
Message 1 of 19
farrukhw
3214 Views, 18 Replies
Hi Guys
I'm using CSharp and I want to call -INSERT command while passing it the path of my dwg files. This call would be done via my DragDrop class.
I tried doc.SendStringToExecute(InsertCmd, true, false, true); but it then waits for user to press enter there...
So how can we call AutoCAD's Commands from our .Net code?
Any help?
18 REPLIES 18
Message 2 of 19
Alfred.NESWADBA
in reply to: farrukhw
Try this (with your blockname):
   Dim tCmd as String = "_INSERT" & vbCr & "C:\TEMP\myBlock.DWG" & vbCr
   doc.SendStringToExecute(tCmd, true, true, false)
The orange parts show how to send <ENTER>
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 19
farrukhw
in reply to: Alfred.NESWADBA
Hi Alferd,
Thanks a lot for quick reply....It worked... I also was reading similar thing (in the example code) here:
http://adndevblog.typepad.com/autocad/2012/06/use-log-file-and-setvar-command-to-get-a-list-of-autoc...
So equivalent of VbCrlf is \r \n and Here is my little code:
        [CommandMethod("cmdTest")]
        static public void SendCmd()
            string File_DWG = @"D:\sym\1047.DWG";
            string InsertCmd = @"_.-INSERT " + File_DWG + '\r' + '\n';
            Document doc = Application.DocumentManager.MdiActiveDocument;
            doc.SendStringToExecute(InsertCmd, true, false, false);
Thanks a bunch
Smiley Happy
Message 4 of 19
matinau
Having the same problem using C#
still didn't work? and causes CAD to crash? Any ideas?
Message 5 of 19
farrukhw
in reply to: matinau
Mine is working properly at this time by adding \r and \n.. Try using only \n...I'm using AutoCAD 2012...
Is that closing AutoCAD? or there is some crash report???
can you please post your code segment?
Message 6 of 19
matinau
I've tried various combinations to no avail? Not sure what's wrong? I'm running 2012, my code passes a blkNam which is present in the block table. It asks for the insertion point and then crashes.
string InsertCmd = @"_.-INSERT " + blkNam + '\r' + '\n';
I've also tried this approach, which works but I can't figure out how to pass the scales prompt?
string InsertCmd = "(command \"_insert\" \"" + blkNam + "\" " + ")\n";
...confused
Message 7 of 19
Alfred.NESWADBA
you can always try it manually by typing the commands/options/values into the command-line .. .and for every <ENTER> you have to use \n instead.
So start typing
_-INSERT<ENTER>
TABLE<ENTER>              ...or whatever your block's name is
....and now see the options you can set before the block is inserted, e.g.
_SCALE<ENTER>
1<ENTER>
So the LISP-result (without C#-conventions) may look like that:
(command "_-INSERT" "TABLE" "_SCALE" "1")
HTH, - alfred -
Alfred NESWADBA
Message 8 of 19
farrukhw
As far I remember, when you issue -INSERT, it will give your Scale, Move and rotate prompt. In addition, while experimenting with different *.dwg files, it also prompted to enter Tag number and at some file, it prompted to Select Tag.
I guess, that is due to the Block Attributes present in that dwg, but I'm not sure...
And -INSERT automate those Prompts for you.
Message 9 of 19
jshimkus
Is there a reason you have to use "-Insert"?
It is my understanding, and general rule to avoid using "Sendcommand" and "Sendstringtoexecute" whenever possible.
Why can't you use dot net and add the desired block to the current drawing database?
Message 10 of 19
matinau
in reply to: jshimkus
Simplicity, I wrote a block insert function in .net but found adding rotate and attribute values overly complicated. Managed to get the sendcommand working, can post later Thanks for everyone's help Sent from my iPhone
Message 11 of 19
farrukhw
Same case here. I wrote .Net routines to move and rotate the Block, but then I realized that it would be complicated when I will have to deal with the behavior related to Block's attributes. So I decided to use built-in functionality.
BTW, why is it that you do not recommend to use built-in functionality?
Message 12 of 19
jshimkus
First of all I'm a dot net newbie so this is mostly from what I've read on the forums. In my actual experience I had a program that used "SendCommand" and when in debug mode it would not run (VB.Net Express). It would crash on the SendCommands so to debug a program I had to comment those lines out.
The program ran fine with the "SendCommand" lines in Release mode, but just not in Debug.
Message 13 of 19
farrukhw
I think, you might be referencing ObjectARX apis in your VB Code.
I'm switched to C# just because of better support and management in .Net Apis.
Message 14 of 19
xsfhlzh1
Try this code
    internal class BlockRefJig : EntityJig
        Point3d m_Position,m_BasePoint;
        double m_Angle;
        int m_PromptCounter;
        Matrix3d m_Ucs;
        Matrix3d m_Mat;
        //键值对集合(属性定义/引用)
        Dictionary<AttributeDefinition, AttributeReference> m_Attribs;
        public BlockRefJig(BlockReference blkref, Dictionary<AttributeDefinition, AttributeReference> attribs)
            : base(blkref)
            m_Position = new Point3d();
            m_Angle = 0;
            m_Ucs = SystemManager.Editor.CurrentUserCoordinateSystem;
            m_Attribs = attribs;
            Update();
        protected override SamplerStatus Sampler(JigPrompts prompts)
            switch (m_PromptCounter)
                case 0:
                        JigPromptPointOptions jigOpts = new JigPromptPointOptions("\n请输入基点:");
                        jigOpts.UserInputControls =
                            UserInputControls.Accept3dCoordinates |
                            UserInputControls.NoZeroResponseAccepted |
                            UserInputControls.NoNegativeResponseAccepted;
                        PromptPointResult res = prompts.AcquirePoint(jigOpts);
                        Point3d pnt = res.Value;
                        if (pnt != m_Position)
                            m_Position = pnt;
                            m_BasePoint = m_Position;
                        else
                            return SamplerStatus.NoChange;
                        if (res.Status == PromptStatus.Cancel)
                            return SamplerStatus.Cancel;
                        else
                            return SamplerStatus.OK;
                case 1:
                        JigPromptAngleOptions jigOpts = new JigPromptAngleOptions("\n请输入旋转角度:");
                            UserInputControls.NoNegativeResponseAccepted |
                            UserInputControls.GovernedByUCSDetect |
                            UserInputControls.UseBasePointElevation;
                        jigOpts.Cursor = CursorType.RubberBand;
                        jigOpts.UseBasePoint = true;
                        jigOpts.BasePoint = m_BasePoint;
                        PromptDoubleResult res = prompts.AcquireAngle(jigOpts);
                        double angleTemp = res.Value;
                        if (angleTemp != m_Angle)
                            m_Angle = angleTemp;
                        else
                        else
                default:
        protected override bool Update()
            try
                /*Ucs下Jig的流程:
                 * 1.先将图元在Wcs下摆正,即//xy平面
                 * 2.将获取点坐标转换到Ucs下
                 * 3.将图元在Ucs下摆正
                 * 4.矩阵变换到Wcs
                BlockReference blkref = (BlockReference)Entity;
                blkref.Normal = Vector3d.ZAxis;
                blkref.Position = m_Position.Wcs2Ucs();
                blkref.Rotation = m_Angle;
                blkref.TransformBy(m_Ucs);
                //将属性引用按块引用的Ocs矩阵变换
                if (m_Attribs != null)
                    m_Mat = blkref.BlockTransform;
                    foreach (KeyValuePair<AttributeDefinition, AttributeReference> att in m_Attribs)
                        AttributeReference attref = att.Value;
                        string s = attref.TextString;
                        attref.SetAttributeFromBlock(att.Key, m_Mat);
                        attref.TextString = s;
            catch
                return false;
            return true;
        public void SetPromptCounter(int i)
            if (i == 0 || i == 1)
                m_PromptCounter = i;
Message 15 of 19
xsfhlzh1
in reply to: xsfhlzh1
        /// <summary>
        /// 添加属性到块参照
        /// </summary>
        /// <param name="blkref">块参照</param>
        /// <param name="atts">属性集合</param>
        /// <returns>属性定义和属性参照对照表</returns>
        public Dictionary<AttributeDefinition, AttributeReference>
            AppendAttribToBlock(BlockReference blkref, List<string> atts)
            var blkdef = GetObject<BlockTableRecord>(blkref.BlockTableRecord);
            int i = 0;
            if (blkdef.HasAttributeDefinitions)
                var attribs =
                    new Dictionary<AttributeDefinition, AttributeReference>();
                var attdefs =
                    blkdef.GetEntities<AttributeDefinition>(Transaction)
                    .Where(attdef => !(attdef.Constant || attdef.Invisible));
                foreach (var attdef in attdefs)
                    AttributeReference attref = new AttributeReference();
                    attref.SetAttributeFromBlock(attdef, blkref.BlockTransform);
                    if (i < atts.Count)
                        attref.TextString = atts[i];
                    else
                        attref.TextString = attdef.TextString;
                    i++;
                    blkref.AttributeCollection.AppendAttribute(attref);
                    Transaction.AddNewlyCreatedDBObject(attref, true);
                    attribs.Add(attdef, attref);
                return attribs;
            return null;
        /// <summary>
        /// 动态添加块参照
        /// </summary>
        /// <param name="blkdefid">块定义Id</param>
        /// <returns>块参照Id</returns>
        public ObjectId InsertBlockRef(ObjectId blkdefid, List<string> atts)
            BlockTableRecord btr = OpenCurrentSpace();
            BlockReference blkref = new BlockReference(Point3d.Origin, blkdefid);
            ObjectId id = AddEntity(btr, blkref);
            BlockRefJig jig = new BlockRefJig(blkref, AppendAttribToBlock(blkref, atts));
            jig.SetPromptCounter(0);
            PromptResult res = Editor.Drag(jig);
            if (res.Status == PromptStatus.OK)
                jig.SetPromptCounter(1);
                    return id;
            blkref.Erase();
            return ObjectId.Null;
Message 16 of 19
farrukhw
Thanks for the code xsfhlzh1.
Can you please upload your Visual Studio Project ? I have errors as we don't have Namespaces used in this code.
Message 17 of 19
xsfhlzh1
using System.Collections.Generic;
using System.Linq;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
[assembly: CommandClass(typeof(InsertBlock.Commands))]
namespace InsertBlock
    public class Commands
        public static Dictionary<AttributeDefinition, AttributeReference>
            AppendAttribToBlock(Transaction tr, BlockReference blkref, List<string> atts)
            var blkdef = (BlockTableRecord)tr.GetObject(blkref.BlockTableRecord, OpenMode.ForRead);
            int i = 0;
                var attribs =
                var attdefs =
                    blkdef.Cast<ObjectId>()
                    .Select(id => tr.GetObject(id, OpenMode.ForRead))
                    .OfType<AttributeDefinition>()
                    if (i < atts.Count)
                    else
                    i++;
                    tr.AddNewlyCreatedDBObject(attref, true);
                return attribs;
            return null;
        public static ObjectId InsertBlockRef(Transaction tr, Database db, Editor ed, ObjectId blkdefid, List<string> atts)
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
            ObjectId id = btr.AppendEntity(blkref);
            tr.AddNewlyCreatedDBObject(blkref, true);
            BlockRefJig jig = new BlockRefJig(blkref, AppendAttribToBlock(tr, blkref, atts));
            PromptResult res = ed.Drag(jig);
                res = ed.Drag(jig);
                    return id;
            blkref.Erase();
        [CommandMethod("MIB")]
        public static void MyInsertBlock()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                ObjectId id;
                if (bt.Has("Test1"))
                    id = bt["Test1"];
                else
                    BlockTableRecord btr = new BlockTableRecord();
                    btr.Name = "Test1";
                    id = bt.Add(btr);
                    tr.AddNewlyCreatedDBObject(btr, true);
                    AttributeDefinition att = new AttributeDefinition(Point3d.Origin, "1", "Number", "input number:", db.Textstyle);
                    att.Height = 6;
                    Circle c = new Circle(Point3d.Origin, Vector3d.ZAxis, 10);
                    btr.AppendEntity(att);
                    tr.AddNewlyCreatedDBObject(att, true);
                    btr.AppendEntity(c);
                    tr.AddNewlyCreatedDBObject(c, true);
                InsertBlockRef(tr, db, ed, id, new List<string> { "1" });
                tr.Commit();
using System;
using System.Diagnostics;
using System.Linq;
using System.Reflection;
        Point3d m_Position, m_BasePoint;
        double m_Angle;
        Matrix3d m_Ucs;
        Matrix3d m_Mat;
        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
        //键值对集合(属性定义/引用)
            : base(blkref)
            m_Angle = 0;
            m_Ucs = ed.CurrentUserCoordinateSystem;
            Update();
                case 0:
                            m_Position = pnt;
                        else
                        else
                case 1:
                        else
                        else
                default:
            try
                /*Ucs下Jig的流程:
                 * 2.将获取点坐标转换到Ucs下
                 * 3.将图元在Ucs下摆正
                 * 4.矩阵变换到Wcs
                blkref.Position = m_Position.TransformBy(ed.CurrentUserCoordinateSystem);
                //将属性引用按块引用的Ocs矩阵变换
            catch
                return false;
            return true;
Message 18 of 19
xsfhlzh1
The above functions are part of the custom class
The following project should you need
Message 19 of 19
farrukhw
Thanks a lot.I'll definitly try that...
Best regards
Farrukh
”Boost
