.NET
.NET
Active Contributor
0 Kudos
Post 11 of 19
Re: Calling -INSERT Command from AutoCAD.net (2012).
07-08-2012 12:08 PM in reply to: matinau
Same case here. I wrote .Net routines to move and rotate the Block, but then I realized that it would be complicated when I will have to deal with the behavior related to Block's attributes. So I decided to use built-in functionality.
BTW, why is it that you do not recommend to use built-in functionality?
Distinguished Contributor
0 Kudos
Post 12 of 19
07-09-2012 03:42 AM in reply to: farrukhw
First of all I'm a dot net newbie so this is mostly from what I've read on the forums. In my actual experience I had a program that used "SendCommand" and when in debug mode it would not run (VB.Net Express). It would crash on the SendCommands so to debug a program I had to comment those lines out.
The program ran fine with the "SendCommand" lines in Release mode, but just not in Debug.
Active Contributor
0 Kudos
Post 13 of 19
07-09-2012 11:58 PM in reply to: CommCorp
I think, you might be referencing ObjectARX apis in your VB Code.
I'm switched to C# just because of better support and management in .Net Apis.
Member
2 Kudos
Post 14 of 19
07-19-2012 01:32 AM in reply to: farrukhw
Try this code
    internal class BlockRefJig : EntityJig
        Point3d m_Position,m_BasePoint;
        double m_Angle;
        int m_PromptCounter;
        Matrix3d m_Ucs;
        Matrix3d m_Mat;
        //键值对集合(属性定义/引用)
        Dictionary<AttributeDefinition, AttributeReference> m_Attribs;
        public BlockRefJig(BlockReference blkref, Dictionary<AttributeDefinition, AttributeReference> attribs)
            : base(blkref)
            m_Position = new Point3d();
            m_Angle = 0;
            m_Ucs = SystemManager.Editor.CurrentUserCoordinateSystem;
            m_Attribs = attribs;
            Update();
        protected override SamplerStatus Sampler(JigPrompts prompts)
            switch (m_PromptCounter)
                case 0:
                        JigPromptPointOptions jigOpts = new JigPromptPointOptions("\n请输入基点:");
                        jigOpts.UserInputControls =
                            UserInputControls.Accept3dCoordinates |
                            UserInputControls.NoZeroResponseAccepted |
                            UserInputControls.NoNegativeResponseAccepted;
                        PromptPointResult res = prompts.AcquirePoint(jigOpts);
                        Point3d pnt = res.Value;
                        if (pnt != m_Position)
                            m_Position = pnt;
                            m_BasePoint = m_Position;
                        else
                            return SamplerStatus.NoChange;
                        if (res.Status == PromptStatus.Cancel)
                            return SamplerStatus.Cancel;
                        else
                            return SamplerStatus.OK;
                case 1:
                        JigPromptAngleOptions jigOpts = new JigPromptAngleOptions("\n请输入旋转角度:");
                            UserInputControls.NoNegativeResponseAccepted |
                            UserInputControls.GovernedByUCSDetect |
                            UserInputControls.UseBasePointElevation;
                        jigOpts.Cursor = CursorType.RubberBand;
                        jigOpts.UseBasePoint = true;
                        jigOpts.BasePoint = m_BasePoint;
                        PromptDoubleResult res = prompts.AcquireAngle(jigOpts);
                        double angleTemp = res.Value;
                        if (angleTemp != m_Angle)
                            m_Angle = angleTemp;
                        else
                        else
                default:
        protected override bool Update()
            try
                /*Ucs下Jig的流程:
                 * 1.先将图元在Wcs下摆正,即//xy平面
                 * 2.将获取点坐标转换到Ucs下
                 * 3.将图元在Ucs下摆正
                 * 4.矩阵变换到Wcs
                BlockReference blkref = (BlockReference)Entity;
                blkref.Normal = Vector3d.ZAxis;
                blkref.Position = m_Position.Wcs2Ucs();
                blkref.Rotation = m_Angle;
                blkref.TransformBy(m_Ucs);
                //将属性引用按块引用的Ocs矩阵变换
                if (m_Attribs != null)
                    m_Mat = blkref.BlockTransform;
                    foreach (KeyValuePair<AttributeDefinition, AttributeReference> att in m_Attribs)
                        AttributeReference attref = att.Value;
                        string s = attref.TextString;
                        attref.SetAttributeFromBlock(att.Key, m_Mat);
                        attref.TextString = s;
            catch
                return false;
            return true;
        public void SetPromptCounter(int i)
            if (i == 0 || i == 1)
                m_PromptCounter = i;
Member
2 Kudos
Post 15 of 19
07-19-2012 01:40 AM in reply to: xsfhlzh1
        /// <summary>
        /// 添加属性到块参照
        /// </summary>
        /// <param name="blkref">块参照</param>
        /// <param name="atts">属性集合</param>
        /// <returns>属性定义和属性参照对照表</returns>
        public Dictionary<AttributeDefinition, AttributeReference>
            AppendAttribToBlock(BlockReference blkref, List<string> atts)
            var blkdef = GetObject<BlockTableRecord>(blkref.BlockTableRecord);
            int i = 0;
            if (blkdef.HasAttributeDefinitions)
                var attribs =
                    new Dictionary<AttributeDefinition, AttributeReference>();
                var attdefs =
                    blkdef.GetEntities<AttributeDefinition>(Transaction)
                    .Where(attdef => !(attdef.Constant || attdef.Invisible));
                foreach (var attdef in attdefs)
                    AttributeReference attref = new AttributeReference();
                    attref.SetAttributeFromBlock(attdef, blkref.BlockTransform);
                    if (i < atts.Count)
                        attref.TextString = atts[i];
                    else
                        attref.TextString = attdef.TextString;
                    i++;
                    blkref.AttributeCollection.AppendAttribute(attref);
                    Transaction.AddNewlyCreatedDBObject(attref, true);
                    attribs.Add(attdef, attref);
                return attribs;
            return null;
        /// <summary>
        /// 动态添加块参照
        /// </summary>
        /// <param name="blkdefid">块定义Id</param>
        /// <returns>块参照Id</returns>
        public ObjectId InsertBlockRef(ObjectId blkdefid, List<string> atts)
            BlockTableRecord btr = OpenCurrentSpace();
            BlockReference blkref = new BlockReference(Point3d.Origin, blkdefid);
            ObjectId id = AddEntity(btr, blkref);
            BlockRefJig jig = new BlockRefJig(blkref, AppendAttribToBlock(blkref, atts));
            jig.SetPromptCounter(0);
            PromptResult res = Editor.Drag(jig);
            if (res.Status == PromptStatus.OK)
                jig.SetPromptCounter(1);
                    return id;
            blkref.Erase();
            return ObjectId.Null;
Active Contributor
0 Kudos
Post 16 of 19
07-20-2012 11:57 PM in reply to: xsfhlzh1
Thanks for the code xsfhlzh1.
Can you please upload your Visual Studio Project ? I have errors as we don't have Namespaces used in this code.
Member
2 Kudos
Post 17 of 19
07-21-2012 01:32 AM in reply to: farrukhw
using System.Collections.Generic;
using System.Linq;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
[assembly: CommandClass(typeof(InsertBlock.Commands))]
namespace InsertBlock
    public class Commands
        public static Dictionary<AttributeDefinition, AttributeReference>
            AppendAttribToBlock(Transaction tr, BlockReference blkref, List<string> atts)
            var blkdef = (BlockTableRecord)tr.GetObject(blkref.BlockTableRecord, OpenMode.ForRead);
            int i = 0;
                var attribs =
                var attdefs =
                    blkdef.Cast<ObjectId>()
                    .Select(id => tr.GetObject(id, OpenMode.ForRead))
                    .OfType<AttributeDefinition>()
                    if (i < atts.Count)
                    else
                    i++;
                    tr.AddNewlyCreatedDBObject(attref, true);
                return attribs;
            return null;
        public static ObjectId InsertBlockRef(Transaction tr, Database db, Editor ed, ObjectId blkdefid, List<string> atts)
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
            ObjectId id = btr.AppendEntity(blkref);
            tr.AddNewlyCreatedDBObject(blkref, true);
            BlockRefJig jig = new BlockRefJig(blkref, AppendAttribToBlock(tr, blkref, atts));
            PromptResult res = ed.Drag(jig);
                res = ed.Drag(jig);
                    return id;
            blkref.Erase();
        [CommandMethod("MIB")]
        public static void MyInsertBlock()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                ObjectId id;
                if (bt.Has("Test1"))
                    id = bt["Test1"];
                else
                    BlockTableRecord btr = new BlockTableRecord();
                    btr.Name = "Test1";
                    id = bt.Add(btr);
                    tr.AddNewlyCreatedDBObject(btr, true);
                    AttributeDefinition att = new AttributeDefinition(Point3d.Origin, "1", "Number", "input number:", db.Textstyle);
                    att.Height = 6;
                    Circle c = new Circle(Point3d.Origin, Vector3d.ZAxis, 10);
                    btr.AppendEntity(att);
                    tr.AddNewlyCreatedDBObject(att, true);
                    btr.AppendEntity(c);
                    tr.AddNewlyCreatedDBObject(c, true);
                InsertBlockRef(tr, db, ed, id, new List<string> { "1" });
                tr.Commit();
using System;
using System.Diagnostics;
using System.Linq;
using System.Reflection;
        Point3d m_Position, m_BasePoint;
        double m_Angle;
        Matrix3d m_Ucs;
        Matrix3d m_Mat;
        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
        //键值对集合(属性定义/引用)
            : base(blkref)
            m_Angle = 0;
            m_Ucs = ed.CurrentUserCoordinateSystem;
            Update();
                case 0:
                            m_Position = pnt;
                        else
                        else
                case 1:
                        else
                        else
                default:
            try
                /*Ucs下Jig的流程:
                 * 2.将获取点坐标转换到Ucs下
                 * 3.将图元在Ucs下摆正
                 * 4.矩阵变换到Wcs
                blkref.Position = m_Position.TransformBy(ed.CurrentUserCoordinateSystem);
                //将属性引用按块引用的Ocs矩阵变换
            catch
                return false;
            return true;
Member
2 Kudos
Post 18 of 19
07-21-2012 01:38 AM in reply to: xsfhlzh1
The above functions are part of the custom class
The following project should you need
Active Contributor
0 Kudos
Post 19 of 19
07-21-2012 02:43 AM in reply to: xsfhlzh1
Thanks a lot.I'll definitly try that...
Best regards
Farrukh
