.NET
.NET
Active Contributor
farrukhw
Message 11 of 19 (439 Views)
Re: Calling -INSERT Command from AutoCAD.net (2012).
07-08-2012 12:08 PM in reply to: matinau
Same case here. I wrote .Net routines to move and rotate the Block, but then I realized that it would be complicated when I will have to deal with the behavior related to Block's attributes. So I decided to use built-in functionality.
BTW, why is it that you do not recommend to use built-in functionality?
Distinguished Contributor
CommCorp
Message 12 of 19 (429 Views)
07-09-2012 03:42 AM in reply to: farrukhw
First of all I'm a dot net newbie so this is mostly from what I've read on the forums. In my actual experience I had a program that used "SendCommand" and when in debug mode it would not run (VB.Net Express). It would crash on the SendCommands so to debug a program I had to comment those lines out.
The program ran fine with the "SendCommand" lines in Release mode, but just not in Debug.
Active Contributor
farrukhw
Message 13 of 19 (417 Views)
07-09-2012 11:58 PM in reply to: CommCorp
I think, you might be referencing ObjectARX apis in your VB Code.
I'm switched to C# just because of better support and management in .Net Apis.
Member
xsfhlzh1
Message 14 of 19 (400 Views)
07-19-2012 01:32 AM in reply to: farrukhw
Try this code
    internal class BlockRefJig : EntityJig
        Point3d m_Position,m_BasePoint;
        double m_Angle;
        int m_PromptCounter;
        Matrix3d m_Ucs;
        Matrix3d m_Mat;
        //键值对集合(属性定义/引用)
        Dictionary<AttributeDefinition, AttributeReference> m_Attribs;
        public BlockRefJig(BlockReference blkref, Dictionary<AttributeDefinition, AttributeReference> attribs)
            : base(blkref)
            m_Position = new Point3d();
            m_Angle = 0;
            m_Ucs = SystemManager.Editor.CurrentUserCoordinateSystem;
            m_Attribs = attribs;
            Update();
        protected override SamplerStatus Sampler(JigPrompts prompts)
            switch (m_PromptCounter)
                case 0:
                        JigPromptPointOptions jigOpts = new JigPromptPointOptions("\n请输入基点:");
                        jigOpts.UserInputControls =
                            UserInputControls.Accept3dCoordinates |
                            UserInputControls.NoZeroResponseAccepted |
                            UserInputControls.NoNegativeResponseAccepted;
                        PromptPointResult res = prompts.AcquirePoint(jigOpts);
                        Point3d pnt = res.Value;
                        if (pnt != m_Position)
                            m_Position = pnt;
                            m_BasePoint = m_Position;
                        else
                            return SamplerStatus.NoChange;
                        if (res.Status == PromptStatus.Cancel)
                            return SamplerStatus.Cancel;
                        else
                            return SamplerStatus.OK;
                case 1:
                        JigPromptAngleOptions jigOpts = new JigPromptAngleOptions("\n请输入旋转角度:");
                            UserInputControls.NoNegativeResponseAccepted |
                            UserInputControls.GovernedByUCSDetect |
                            UserInputControls.UseBasePointElevation;
                        jigOpts.Cursor = CursorType.RubberBand;
                        jigOpts.UseBasePoint = true;
                        jigOpts.BasePoint = m_BasePoint;
                        PromptDoubleResult res = prompts.AcquireAngle(jigOpts);
                        double angleTemp = res.Value;
                        if (angleTemp != m_Angle)
                            m_Angle = angleTemp;
                        else
                        else
                default:
        protected override bool Update()
            try
                /*Ucs下Jig的流程:
                 * 1.先将图元在Wcs下摆正,即//xy平面
                 * 2.将获取点坐标转换到Ucs下
                 * 3.将图元在Ucs下摆正
                 * 4.矩阵变换到Wcs
                BlockReference blkref = (BlockReference)Entity;
                blkref.Normal = Vector3d.ZAxis;
                blkref.Position = m_Position.Wcs2Ucs();
                blkref.Rotation = m_Angle;
                blkref.TransformBy(m_Ucs);
                //将属性引用按块引用的Ocs矩阵变换
                if (m_Attribs != null)
                    m_Mat = blkref.BlockTransform;
                    foreach (KeyValuePair<AttributeDefinition, AttributeReference> att in m_Attribs)
                        AttributeReference attref = att.Value;
                        string s = attref.TextString;
                        attref.SetAttributeFromBlock(att.Key, m_Mat);
                        attref.TextString = s;
            catch
                return false;
            return true;
        public void SetPromptCounter(int i)
            if (i == 0 || i == 1)
                m_PromptCounter = i;
Member
xsfhlzh1
Message 15 of 19 (399 Views)
07-19-2012 01:40 AM in reply to: xsfhlzh1
        /// <summary>
        /// 添加属性到块参照
        /// </summary>
        /// <param name="blkref">块参照</param>
        /// <param name="atts">属性集合</param>
        /// <returns>属性定义和属性参照对照表</returns>
        public Dictionary<AttributeDefinition, AttributeReference>
            AppendAttribToBlock(BlockReference blkref, List<string> atts)
            var blkdef = GetObject<BlockTableRecord>(blkref.BlockTableRecord);
            int i = 0;
            if (blkdef.HasAttributeDefinitions)
                var attribs =
                    new Dictionary<AttributeDefinition, AttributeReference>();
                var attdefs =
                    blkdef.GetEntities<AttributeDefinition>(Transaction)
                    .Where(attdef => !(attdef.Constant || attdef.Invisible));
                foreach (var attdef in attdefs)
                    AttributeReference attref = new AttributeReference();
                    attref.SetAttributeFromBlock(attdef, blkref.BlockTransform);
                    if (i < atts.Count)
                        attref.TextString = atts[i];
                    else
                        attref.TextString = attdef.TextString;
                    i++;
                    blkref.AttributeCollection.AppendAttribute(attref);
                    Transaction.AddNewlyCreatedDBObject(attref, true);
                    attribs.Add(attdef, attref);
                return attribs;
            return null;
        /// <summary>
        /// 动态添加块参照
        /// </summary>
        /// <param name="blkdefid">块定义Id</param>
        /// <returns>块参照Id</returns>
        public ObjectId InsertBlockRef(ObjectId blkdefid, List<string> atts)
            BlockTableRecord btr = OpenCurrentSpace();
            BlockReference blkref = new BlockReference(Point3d.Origin, blkdefid);
            ObjectId id = AddEntity(btr, blkref);
            BlockRefJig jig = new BlockRefJig(blkref, AppendAttribToBlock(blkref, atts));
            jig.SetPromptCounter(0);
            PromptResult res = Editor.Drag(jig);
            if (res.Status == PromptStatus.OK)
                jig.SetPromptCounter(1);
                    return id;
            blkref.Erase();
            return ObjectId.Null;
Active Contributor
farrukhw
Message 16 of 19 (377 Views)
07-20-2012 11:57 PM in reply to: xsfhlzh1
Thanks for the code xsfhlzh1.
Can you please upload your Visual Studio Project ? I have errors as we don't have Namespaces used in this code.
Member
xsfhlzh1
Message 17 of 19 (371 Views)
07-21-2012 01:32 AM in reply to: farrukhw
using System.Collections.Generic;
using System.Linq;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
[assembly: CommandClass(typeof(InsertBlock.Commands))]
namespace InsertBlock
    public class Commands
        public static Dictionary<AttributeDefinition, AttributeReference>
            AppendAttribToBlock(Transaction tr, BlockReference blkref, List<string> atts)
            var blkdef = (BlockTableRecord)tr.GetObject(blkref.BlockTableRecord, OpenMode.ForRead);
            int i = 0;
                var attribs =
                var attdefs =
                    blkdef.Cast<ObjectId>()
                    .Select(id => tr.GetObject(id, OpenMode.ForRead))
                    .OfType<AttributeDefinition>()
                    if (i < atts.Count)
                    else
                    i++;
                    tr.AddNewlyCreatedDBObject(attref, true);
                return attribs;
            return null;
        public static ObjectId InsertBlockRef(Transaction tr, Database db, Editor ed, ObjectId blkdefid, List<string> atts)
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
            ObjectId id = btr.AppendEntity(blkref);
            tr.AddNewlyCreatedDBObject(blkref, true);
            BlockRefJig jig = new BlockRefJig(blkref, AppendAttribToBlock(tr, blkref, atts));
            PromptResult res = ed.Drag(jig);
                res = ed.Drag(jig);
                    return id;
            blkref.Erase();
        [CommandMethod("MIB")]
        public static void MyInsertBlock()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                ObjectId id;
                if (bt.Has("Test1"))
                    id = bt["Test1"];
                else
                    BlockTableRecord btr = new BlockTableRecord();
                    btr.Name = "Test1";
                    id = bt.Add(btr);
                    tr.AddNewlyCreatedDBObject(btr, true);
                    AttributeDefinition att = new AttributeDefinition(Point3d.Origin, "1", "Number", "input number:", db.Textstyle);
                    att.Height = 6;
                    Circle c = new Circle(Point3d.Origin, Vector3d.ZAxis, 10);
                    btr.AppendEntity(att);
                    tr.AddNewlyCreatedDBObject(att, true);
                    btr.AppendEntity(c);
                    tr.AddNewlyCreatedDBObject(c, true);
                InsertBlockRef(tr, db, ed, id, new List<string> { "1" });
                tr.Commit();
using System;
using System.Diagnostics;
using System.Linq;
using System.Reflection;
        Point3d m_Position, m_BasePoint;
        double m_Angle;
        Matrix3d m_Ucs;
        Matrix3d m_Mat;
        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
        //键值对集合(属性定义/引用)
            : base(blkref)
            m_Angle = 0;
            m_Ucs = ed.CurrentUserCoordinateSystem;
            Update();
                case 0:
                            m_Position = pnt;
                        else
                        else
                case 1:
                        else
                        else
                default:
            try
                /*Ucs下Jig的流程:
                 * 2.将获取点坐标转换到Ucs下
                 * 3.将图元在Ucs下摆正
                 * 4.矩阵变换到Wcs
                blkref.Position = m_Position.TransformBy(ed.CurrentUserCoordinateSystem);
                //将属性引用按块引用的Ocs矩阵变换
            catch
                return false;
            return true;
Member
xsfhlzh1
Message 18 of 19 (369 Views)
07-21-2012 01:38 AM in reply to: xsfhlzh1
The above functions are part of the custom class
The following project should you need
Active Contributor
farrukhw
Message 19 of 19 (363 Views)
07-21-2012 02:43 AM in reply to: xsfhlzh1
Thanks a lot.I'll definitly try that...
Best regards
Farrukh
