.NET
.NET
Active Contributor
0 Kudos
Post 1 of 19
Calling -INSERT Command from AutoCAD.net (2012).
949 Views, 18 Replies
07-03-2012 03:39 AM
Hi Guys
I'm using CSharp and I want to call -INSERT command while passing it the path of my dwg files. This call would be done via my DragDrop class.
I tried doc.SendStringToExecute(InsertCmd, true, false, true); but it then waits for user to press enter there...
So how can we call AutoCAD's Commands from our .Net code?
Any help?
Try this (with your blockname):
   Dim tCmd as String = "_INSERT" & vbCr & "C:\TEMP\myBlock.DWG" & vbCr
   doc.SendStringToExecute(tCmd, true, true, false)
The orange parts show how to send <ENTER>
- alfred -
1,219 Kudos
Post 2 of 19
Re: Calling -INSERT Command from AutoCAD.net (2012).
07-03-2012 04:00 AM in reply to: farrukhw
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 3 of 19
07-03-2012 04:52 AM in reply to: Alfred.NESWADBA
Hi Alferd,
Thanks a lot for quick reply....It worked... I also was reading similar thing (in the example code) here:
http://adndevblog.typepad.com/autocad/2012/06/use-log-file-and-setvar-command-to-get-a-list-of-autoc...
So equivalent of VbCrlf is \r \n and Here is my little code:
        [CommandMethod("cmdTest")]
        static public void SendCmd()
            string File_DWG = @"D:\sym\1047.DWG";
            string InsertCmd = @"_.-INSERT " + File_DWG + '\r' + '\n';
            Document doc = Application.DocumentManager.MdiActiveDocument;
            doc.SendStringToExecute(InsertCmd, true, false, false);
Thanks a bunch
:smileyhappy:
1 Kudo
Post 4 of 19
07-04-2012 02:02 AM in reply to: farrukhw
Having the same problem using C#
still didn't work? and causes CAD to crash? Any ideas?
Active Contributor
0 Kudos
Post 5 of 19
07-04-2012 02:23 AM in reply to: matinau
Mine is working properly at this time by adding \r and \n.. Try using only \n...I'm using AutoCAD 2012...
Is that closing AutoCAD? or there is some crash report???
can you please post your code segment?
1 Kudo
Post 6 of 19
07-04-2012 02:58 AM in reply to: farrukhw
I've tried various combinations to no avail? Not sure what's wrong? I'm running 2012, my code passes a blkNam which is present in the block table. It asks for the insertion point and then crashes.
string InsertCmd = @"_.-INSERT " + blkNam + '\r' + '\n';
I've also tried this approach, which works but I can't figure out how to pass the scales prompt?
string InsertCmd = "(command \"_insert\" \"" + blkNam + "\" " + ")\n";
...confused
1,219 Kudos
Post 7 of 19
07-04-2012 04:17 AM in reply to: matinau
you can always try it manually by typing the commands/options/values into the command-line .. .and for every <ENTER> you have to use \n instead.
So start typing
_-INSERT<ENTER>
TABLE<ENTER>              ...or whatever your block's name is
....and now see the options you can set before the block is inserted, e.g.
_SCALE<ENTER>
1<ENTER>
So the LISP-result (without C#-conventions) may look like that:
(command "_-INSERT" "TABLE" "_SCALE" "1")
HTH, - alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 8 of 19
07-04-2012 05:48 AM in reply to: matinau
As far I remember, when you issue -INSERT, it will give your Scale, Move and rotate prompt. In addition, while experimenting with different *.dwg files, it also prompted to enter Tag number and at some file, it prompted to Select Tag.
I guess, that is due to the Block Attributes present in that dwg, but I'm not sure...
And -INSERT automate those Prompts for you.
Distinguished Contributor
0 Kudos
Post 9 of 19
07-05-2012 05:08 AM in reply to: farrukhw
Is there a reason you have to use "-Insert"?
It is my understanding, and general rule to avoid using "Sendcommand" and "Sendstringtoexecute" whenever possible.
Why can't you use dot net and add the desired block to the current drawing database?
1 Kudo
Post 10 of 19
07-05-2012 05:15 AM in reply to: CommCorp
Simplicity, I wrote a block insert function in .net but found adding rotate and attribute values overly complicated. Managed to get the sendcommand working, can post later Thanks for everyone's help Sent from my iPhone
