.NET
16 Kudos
Post 1 of 9
Call Rejected by Callee
760 Views, 8 Replies
07-30-2012 10:36 PM
I am in a new Project in  where i am using VB.net. More frequently i am getting message Call Rejected by Callee. I searched the Net on how to handle Call Rejected by Callee bout found in C#.net.
Any body has code in VB.net to handle Call Rejected by Callee
Regards
Amit
This code is working good on my end
And also take a look at this article:
http://msdn.microsoft.com/en-us/library/ms228772.aspx
especialy see the very last user response that was written on VB.NET
~'J'~
171 Kudos
Post 2 of 9
Re: Call Rejected by Callee
07-30-2012 11:11 PM in reply to: amitk_189
Take a look at this article
http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
~'J'~
16 Kudos
Post 3 of 9
07-30-2012 11:15 PM in reply to: amitk_189
Hello Hallex, I referred to this part of code earlier also. But the code is in C#, i am converting this to VB.net but its not working still call rejected by callee
With Warm Regards
Amit
171 Kudos
Post 4 of 9
07-30-2012 11:57 PM in reply to: amitk_189
I know nothing about your code,
have you tried to compile your peroject
in Release mode, sometime it helps
~'J'~
16 Kudos
Post 5 of 9
07-31-2012 12:06 AM in reply to: amitk_189
Ok Hallex, I will try
With Warm Regards
Amit
16 Kudos
Post 6 of 9
07-31-2012 12:25 AM in reply to: amitk_189
Hello Hallex, I am executing the part of code which was provided by you in this link
http://forums.autodesk.com/t5/NET/Select-All/td-p/3551324
171 Kudos
Post 7 of 9
07-31-2012 03:23 AM in reply to: amitk_189
~'J'~
16 Kudos
Post 8 of 9
07-31-2012 03:59 AM in reply to: Hallex
Wow, Superb Hallex It solved my major problem. Actually my whole project is based on MultiThreading.
And i was processing hundreds of AutoCAD files in fixed time. But every time it used to get stuck in this bug. The link which you provided was really helpful and it resolved many errors. Thank you once again. Thanks a lot Hallex :smileyhappy:
With Warm Regards
Amit
171 Kudos
Post 9 of 9
07-31-2012 05:50 AM in reply to: amitk_189
Glad to help,
Happy coding,
~'J'~
