.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 7
Call a procedure involving pick points recursively
8404 Views, 6 Replies
09-25-2013 02:28 PM
Hi all,
I am in the process of translating existing VBA code into VB.NET, and I just ran into some issues regarding how to interpret VBA's GOTO in VB.NET. In the VBA, the programmer has the code written thus...
Public Sub addTag()
Dim ptStart, ptEnd As Variant
Dim annotation As Object
Dim leader As AcadLeader
On Error Resume Next
StartAddTag:
' Pick start point
ptStart=ThisDrawing.Utility.GetPoint(, vbCrLf & "Select item to tag: ")
' Pick end point
ptEnd=ThisDrawing.Utility.GetPoint(ptStart, vbCrLf & "Select tag location: ")
Set annotation=ThisDrawing.ModelSpace.InsertBlock(ptEnd,"C:/tag.dwg",1,1,1,0)
' Add a leader to the drawing and set its annotation
Set leader=ThisDrawing.ModelSpace.AddLeader(ptStart,ptEnd,annotation,acLineWithArrow)
GoTo StartAddTag
End Sub
My VB.NET translation is thus...
Dim tbl As BlockTable
Dim mSpace As BlockTableRecord
Dim acTrans As Transaction
Dim db As Database
' Gets picked points from user
Private Function pickPoints() As Boolean
pickPoints = True
Dim res As PromptPointResult
Dim opts As PromptPointOptions = New PromptPointOptions("")
Dim acDoc As Document = acApp.DocumentManager.MdiActiveDocument
' Prompt for start point
opts.Message = vbLf & "Select item to tag: "
res = acDoc.Editor.GetPoint(opts)
ptStart = res.Value
' Exit if user presses ESC or cancels command
If res.Status = PromptStatus.Cancel Then
pickPoints = False
Exit Function
End If
' Prompt for end point
opts.Message = vbLf & "Select tag location: "
opts.UseBasePoint = True
opts.BasePoint = ptStart
ptEnd = res.Value
pickPoints = False
Exit Function
End If
End Function
' Sets the modelspace and block table
Private Sub setModelSpace()
tbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
mSpace = acTrans.GetObject(tbl(BlockTableRecord.ModelSpace), _
OpenMode.ForWrite)
End Sub
' Adds a tag to modelspace, comprising of a leader with block annotation
Public Sub addTag()
While pickPoints()
acTrans = db.TransactionManager.StartTransaction()
Using acTrans
setModelSpace()
Dim blockId As ObjectId = insertTagBlock() ' works perfectly, adds the block
addLeader(getLeaderIntersect(), blockId) ' works perfectly, adds the leader
acTrans.Commit()
End Using
End While
End Sub
Without the while loop, single execution works perfectly. But the while loop to emulate multiple (recursive) execution raises some issues.
My problem occurs during execution of my VB.NET code, and has to do with display of the generated entities after the user picks points.
User picks the start point, then picks the end point, but nothing is displayed in the modelspace; rather, user is prompted immediately to pick start point and end point all over again (because of the while loop I used to emulate VBA's GOTO).
However, once user presses ESC, all the leaders and blocks that were drawn during the execution of the while loop are immediately displayed.
Is there a way for me to make it so that EACH time the while loop executes, the end product is IMMEDIATELY displayed in modelspace at the end of EACH loop, BEFORE the user is prompted to pick points all over again (beginning of the next loop)?
The VBA code executes as expected during runtime, as a result of the GOTO StartAddTag line of code.
But I can't use GOTO in my VB.NET code because of its messy nature, so I used a while loop instead. And the while loop isn't performing as expected. So, any suggestions?
Please feel free to request for additional information or clarification, if required.
Any help at all is greatly appreciated.
Thanks all...
Cat
Here is my 2 cents, though it is from my oldies and badly designed one:
 Public Sub MultipleGetPoint(ByRef ok As Boolean, ByRef pts As List(Of Point3d))
' credits to Kean Walmsley
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
pts = New List(Of Point3d)
ok = False
Try
' Prompt will be reused in our loop
Dim ppo As New PromptPointOptions(vbLf & "Pick a point (or press Enter to Exit): ")
ppo.AllowNone = True
' List of the points selected and our result object
Dim ppr As PromptPointResult
' The selection loop
Do
' If we have a valid point selection, add it to the list
ppr = ed.GetPoint(ppo)
If ppr.Status = PromptStatus.OK Then
pts.Add(ppr.Value)
End If
Loop While ppr.Status = PromptStatus.OK
' The loop will continue until a non-OK result...
' We only care if Enter was used to terminate
'Just to display a result:
'For Each p As Point3d In pts
' ed.WriteMessage(vbLf & "{0:f5}" & vbTab & "{1:f5}" & vbTab & "{2:f5}", p.X, p.Y, p.Z)
'Next
If (pts.Count > 0) Then
ok = True
Else
ok = False
End If
Catch
ok = False
Return
End Try
End Sub
<CommandMethod("LPP", CommandFlags.UsePickSet)> _
Public Sub testLoop()
Dim db As Database = doc.Database
Dim test As Boolean = False
Dim points As New List(Of Point3d)
doc.TransactionManager.EnableGraphicsFlush(True)
Using tr As Transaction = db.TransactionManager.StartTransaction
Do
MultipleGetPoint(test, points)
If Not test Then
Exit Do
End If
Dim poly As Autodesk.AutoCAD.DatabaseServices.Polyline = New Autodesk.AutoCAD.DatabaseServices.Polyline()
For Each pp As Point3d In points
poly.AddVertexAt(0, New Point2d(pp.X, pp.Y), 0.0, 0.0, 0.0)
Next
For i As Integer = 0 To points.Count - 2
ed.DrawVector(points(i), points(i + 1), 3, False)
Next
Dim btr As BlockTableRecord = tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite)
btr.AppendEntity(poly)
tr.AddNewlyCreatedDBObject(poly, True)
poly.ColorIndex = 1
tr.TransactionManager.QueueForGraphicsFlush()
Loop
doc.TransactionManager.FlushGraphics()
tr.Commit()
ed.Regen()
End Using
End Sub
255 Kudos
Post 2 of 7
Re : Call a procedure involving pick points recursively
09-25-2013 11:16 PM in reply to: mindofcat
First, I had to say this as nothing to do with recursion, this is a simple loop statement.
To mimic the autoCAD commands, you can exit the Sub if the user escapes (this aborts the transaction and rolls back any changes) or exit the while loop and go on executing the rest of the code (commit the transaction to save the changes).
To display the changes before the transaction is commited and disposed from within the While loop, you can call the Database.TransactionManager.QueueForGraphicFlush() method.
Here's a non tested example which may contains errors (VB is not at all my prefered language)
        Public Sub AddTag()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim mSpace As BlockTableRecord = _
DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord) ' Start a while loop until user pick start and end points While True ' Prompt for start point opts.Message = vbLf & "Select item to tag: " res = ed.GetPoint(opts) ' Exit sub if user presses ESC or cancels command If res.Status = PromptStatus.Cancel Then Exit Sub End If ' Break the while loop if user does not pick a point (Enter or right click) If res.Status <> PromptStatus.OK Then Exit While End If ptStart = res.Value ' Prompt for end point opts.Message = vbLf & "Select tag location: " opts.UseBasePoint = True opts.BasePoint = ptStart res = ed.GetPoint(opts) ' Exit if user presses ESC or cancels command If res.Status = PromptStatus.Cancel Then Exit Sub End If ' Break the while loop if user does not pick a point (Enter or right click) If res.Status <> PromptStatus.OK Then Exit While End If ptEnd = res.Value ' Add the block and the leader to Model Space Dim blockId As ObjectId = insertTagBlock() addLeader(getLeaderIntersect(), blockId) ' Force newly added objects to display db.TransactionManager.QueueForGraphicsFlush() End While tr.Commit() End Using
Gilles Chanteau
255 Kudos
Post 3 of 7
09-26-2013 12:55 AM in reply to: mindofcat
About recursion, basicaly a recursive method is a method which calls itself from within its own definition.
For example, using recursion is the only way to scan a tree structure you don't the nested depth.
Here's a simple example to get all DWG files in a directory and all the sub-directories.
Imperative way (filling a List(of String) passed as argument.
    Sub GetAllDwgFiles(ByVal rootFolder As String, ByVal fileNames As List(Of String))
        For Each file As String In Directory.GetFiles(rootFolder, "*.dwg")
            fileNames.Add(file)
        Next
        For Each dir As String In Directory.GetDirectories(rootFolder)
            GetAllDwgFiles(dir, fileNames) '<- recursive call
        Next
    End Sub
 Or, in a more functional style (using Linq and returning an IEnumerable(Of string))
    Function GetAllDwgFiles(ByVal rootFolder As String) As IEnumerable(Of String)
        Return _
            Directory.GetFiles(rootFolder, "*.dwg") _
            .Concat(Directory.GetDirectories(rootFolder).SelectMany(Function(dir) GetDwgFiles(dir)))
    End Function
Gilles Chanteau
171 Kudos
Post 4 of 7
Re: Call a procedure involving pick points recursively
09-26-2013 01:22 AM in reply to: mindofcat
            ok = False
            Try
                Do
                        pts.Add(ppr.Value)
                    End If
                'Next
                    ok = True
                Else
                    ok = False
                End If
            Catch
                ok = False
                Return
            End Try
        End Sub
                Do
                    If Not test Then
                        Exit Do
                    End If
                    Next
                    Next
                    poly.ColorIndex = 1
                Loop
                tr.Commit()
                ed.Regen()
            End Using
        End Sub
255 Kudos
Post 5 of 7
09-26-2013 01:31 AM in reply to: Hallex
Oopss!
Hallex code (thanks Oleg) shows me I forgot to set the PromptPointOptions.AllowNone to True so that the user can exit the loop typing Enter (or right click).
Gilles Chanteau
171 Kudos
Post 6 of 7
09-26-2013 02:42 AM in reply to: _gile
Gilles,
Your codes are true works of art,
I always copy them to my collection for
future needs
My great respect,
Oleg
Valued Contributor
1 Kudo
Post 7 of 7
09-26-2013 01:00 PM in reply to: Hallex
I am overwhelmed with gratitude at the quick responses to this seemingly difficult problem of mine!
Gilles' code did the trick! And now I also learned something new, how to use the TransactionManager.QueueForGraphicsFlush() function
Thanks Gilles, thanks Hallex, your contributions are much appreciated.
Best regards,
Cat
