.NET
Alfred.NESWADBA
Message 11 of 12 (146 Views)
Re: Calculate the Area of a layer
10-08-2012 09:23 PM in reply to: AakashChopra
>> How can we find the area of particular objectID
That is already visible in my code above, if you have a given ObjectID you can start at this line:
Dim tCurve As Curve = CType(tTrAct.GetObject(tObjID, OpenMode.ForRead), Curve)
But make sure that the ObjectID is from an object that can be casted to a curve. Maybe the better syntax is then to use TryCast instead of CType:
Dim tCurve As Curve = TryCast(tTrAct.GetObject(tObjID, OpenMode.ForRead), Curve)
If tCurve isNot nothing then
   'if you land here you know that the object
   'can be casted to a Curve and so you can
   'get an area from it
- alfred -
Alfred NESWADBA
Hallex
Message 12 of 12 (137 Views)
10-09-2012 01:38 AM in reply to: AakashChopra
Try this code using Linq query:
     ' Add to Imports :
       ' Imports System.Linq
        <CommandMethod("tar")> _
        Public Shared Sub SubTotalAreasByLayer()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim tr As Transaction = db.TransactionManager.StartTransaction
            Try
                Using tr
                    ' Get the BlockTable
                    Dim tb As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                    ' Get the current space block
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord)
                    ' Loop through the current space block
                    ' Create Group By Linq query
                    Dim cummareas = From id As ObjectId In btr _
                        Where (id.IsValid And id.IsResident And id.ObjectClass.DxfName Like "*POLYLINE*") _
                        Let curv = DirectCast(tr.GetObject(id, OpenMode.ForRead), Curve) _
                        Where (curv.Closed) _
                        Group curv By key = curv.Layer Into Group, ar = Sum(curv.Area) _
                        Select layer = key, subtotal = ar, name = Group
                    ' Get the query results  by group
                    For Each grouparea In cummareas
                        ' Get the grouping value and the total area
                        ed.WriteMessage(vbLf & "Layer: {0} ---> Total Area: {1}", grouparea.layer, grouparea.subtotal)
                    Next
                    ' Commit transaction
                    tr.Commit()
                End Using
            Catch ex As System.Exception
                ed.WriteMessage(vbLf & "Error: " & ex.Message & vbLf & "Trace: " & ex.StackTrace)
            Finally
                ed.WriteMessage(vbLf & "Pokey!")
            End Try
        End Sub
~'J'~
