.NET
AakashChopra
Message 1 of 12 (987 Views)
Calculate the Area of a layer
987 Views, 11 Replies
10-07-2012 04:34 AM
How to Calcuate the area of a layer, through .NET API ?
without island-calculation and to verify the results!
 ''' <summary>calcAreaPLinesByLayer scans through the modelspace and calculates areas of closed polylines (dxf-typename like *POLYLINE*)</summary>
''' <remarks></remarks>
<Autodesk.AutoCAD.Runtime.CommandMethod("calcAreaPLinesByLayer")> _
Public Shared Sub calcAreaPLinesByLayer()
Dim tCumArea As SortedList(Of String, Double) = New SortedList(Of String, Double)
Dim tEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim tDb As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tTrAct As Transaction = Nothing
Try
tTrAct = tDb.TransactionManager.StartTransaction
'get BlockTable
Dim tBlTab As BlockTable = CType(tTrAct.GetObject(tDb.BlockTableId, OpenMode.ForRead), BlockTable)
'get ModelSpace
Dim tModSp As BlockTableRecord = CType(tTrAct.GetObject(tBlTab("*MODEL_SPACE"), OpenMode.ForRead), BlockTableRecord)
'scan through ModelSpace
For Each tObjID As ObjectId In tModSp
If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) AndAlso (tObjID.ObjectClass.DxfName Like "*POLYLINE*") Then
Dim tCurve As Curve = CType(tTrAct.GetObject(tObjID, OpenMode.ForRead), Curve)
If tCurve.Closed OrElse (tCurve.StartPoint.DistanceTo(tCurve.EndPoint) < 0.0000001) Then
'ok, it's a poly and it's closed
Try
Dim tArea As Double = tCurve.Area
Dim tLayer As String = tCurve.Layer
If tCumArea.ContainsKey(tLayer) Then
tCumArea.Item(tLayer) += tArea
Else
tCumArea.Add(tLayer, tArea)
End If
Catch ex2 As Exception
tEd.WriteMessage(vbNewLine & "Error calculating area for Polyline Handle = &h" & Hex(tCurve.Handle.Value) & ", EX2 = " & ex2.Message)
End Try
End If
End If
Next
'now write the areas counted/cumulated
For Each tItem As KeyValuePair(Of String, Double) In tCumArea
tEd.WriteMessage(vbNewLine & tItem.Key & ": " & tItem.Value.ToString)
Next
Catch ex As Exception
tEd.WriteMessage(vbNewLine & "Unknown Error occured, EX = " & ex.Message)
Finally
If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
End Try
End Sub
- alfred -
Alfred.NESWADBA
Message 2 of 12 (984 Views)
Re: Calculate the Area of a layer
10-07-2012 04:36 AM in reply to: AakashChopra
a layer (LayerTableRecord) is no geometrey object, so it has no area as property or to calculate.
Can you try to declare it in other words?
- alfred -
Alfred NESWADBA
AakashChopra
Message 3 of 12 (981 Views)
10-07-2012 04:41 AM in reply to: Alfred.NESWADBA
ya, or can you please guide me, how to calculate all entity/object wise of a layer ?
Alfred.NESWADBA
Message 4 of 12 (972 Views)
10-07-2012 04:49 AM in reply to: AakashChopra
What objecttypes are you working with? Not every object has an area, e.g. Node, Text, Dimensions, BlockReference, also 3D-Solids and a lot more.
The easiest way would be to create a selectionset that is filtered to the layername you like. Then you can scan through the entities within the selectionset and verify if the objecttype is derived from type DatabaseServices.Curve and then if it's property "closed" = true, if so you can read the area-property.
That's the theory, but there are also a lot of obstacles to get passed like 3d-polyline or self-crossing polylines or how to work with solids, with polylines in blocks, objects not oriented plane to XY, ....
Can you describe how your drawings are structures (or upload a typical sample drawing you have to test your app) and what your goal is with this area-calculation?
- alfred -
Alfred NESWADBA
AakashChopra
Message 5 of 12 (930 Views)
10-07-2012 11:56 PM in reply to: Alfred.NESWADBA
We have a floor drawing file which contains few layers like Exterior Wall, Interior Wall, etc.
We have to calculate the square feet of the area covered by each layer.
Could you please guide us how to calculate the total area covered by these layers?
Alfred.NESWADBA
Message 6 of 12 (920 Views)
10-08-2012 01:30 AM in reply to: AakashChopra
And again I don't know what object-types you are speaking from. Are these walls polylines or lines or walls created by Autodesk-Architecture?
BTW: do you really want to calculate the area of the wall(s)? ... or is it the area of the rooms you want to get?
- alfred -
Alfred NESWADBA
AakashChopra
Message 7 of 12 (913 Views)
10-08-2012 02:31 AM in reply to: Alfred.NESWADBA
The object types are polylines.
Here is the attached sample dwg file screen shot.
I have shown the layers that are present in the dwg file and the spaces that are present in those layers.
I want to calculate the area of the spaces that are associated with the layers.
Alfred.NESWADBA
Message 8 of 12 (905 Views)
10-08-2012 03:31 AM in reply to: AakashChopra
		Try
			'get BlockTable
			'get ModelSpace
						Try
							Else
							End If
						End Try
					End If
				End If
			Next
			Next
		Finally
		End Try
	End Sub
- alfred -
Alfred NESWADBA
AakashChopra
Message 9 of 12 (892 Views)
10-08-2012 04:57 AM in reply to: Alfred.NESWADBA
Thank you very much for the response and the code
Looking forward to seek help from you in the future...
AakashChopra
Message 10 of 12 (848 Views)
10-08-2012 09:04 PM in reply to: Alfred.NESWADBA
I am having a similar kind of doubt,
How can we find the area of particular objectID for the same dwg file?
    Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
    Dim acSSet As SelectionSet = acSSPrompt.Value
    Dim acObjId As ObjectId
    For Each acObjId In acSSet.GetObjectIds()
        acObjIdColl.Add(acObjId)
    Next
