.NET
Valued Contributor
0 Kudos
Post 1 of 7
Caculate the Point to the Screen?
379 Views, 6 Replies
04-03-2013 01:56 AM
Hi,everyone. I want to do something like that.
I draw something one the drawing fisrt,
then open one windows form。
The problem is the form location。I do not want the form cover the graphic what i was drawing before.
Is there anyone could give me some mind about that? Maybe, there is a way to Caculate the Point of the screen by Entity
Position!
Without P/Invoke it will be possible also with Editor.PointToScreen and Editor.PointToWorld
1,219 Kudos
Post 2 of 7
Re: Caculate the Point to the Screen?
04-03-2013 02:26 AM in reply to: kevinsir
you can get your current mouse-coords (Windows) with that option:
Dim tScreenCoords As System.Drawing.Point = System.Windows.Forms.Control.MousePosition
And if you load your form you can define it's postion by:
Me.Location = tScreenCoords
or if you need any offset
Me.Location = New System.Drawing.Point(tScreenCoords.X + Offset.X, tScreenCoords.Y + Offset.Y)
(where "Me" stands for the form-object-instance)
Make sure to set the property .StartPosition of the form-object like that
Me.StartPosition = Windows.Forms.FormStartPosition.Manual
HTH, - alfred -
Alfred NESWADBA
Valued Contributor
0 Kudos
Post 3 of 7
04-03-2013 02:36 AM in reply to: Alfred.NESWADBA
Thanks for your reply! However, set the mouse position as the form location,maybe can solve it when the drawing is from left to right, but drawing from right to left  will be not right!
1,219 Kudos
Post 4 of 7
04-03-2013 03:11 AM in reply to: kevinsir
then you might calculate the position of your text in modelspace (WCS) and use then >>>acedCoordFromWorldToPixel<<< to calculate the position for your form.
At >>>this blog<<< from Kean Walmsley you find a method for how to invoke the function from a dotNET application.
Scroll down or use search to find this statement:
[DllImport("acad.exe", EntryPoint="?acedCoordFromWorldToPixel@@YAHHQBNAAVCPoint@@@Z")]
Be careful, 32bit and 64bit are different for that declaration:
32bit:  EntryPoint:="?acedCoordFromWorldToPixel@@YAHHQBNAAVCPoint@@@Z"
64bit:  EntryPoint:="?acedCoordFromWorldToPixel@@YAHHQEBNAEAVCPoint@@@Z"
HTH, - alfred -
Alfred NESWADBA
Moderator
277 Kudos
Post 5 of 7
04-03-2013 10:47 AM in reply to: Alfred.NESWADBA
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
0 Kudos
Post 6 of 7
04-07-2013 01:14 AM in reply to: Alexander.Rivilis
Yeah,It is the answer! However, it is not the point to the Screen, It is the point to the mdi window  of  the Document, I use some transformations, then solve it. Thanks!
New Member
0 Kudos
Post 7 of 7
01-20-2014 11:55 AM in reply to: kevinsir
Would you mind sharing your transformation code to go from mdi pixel to screen pixel? I have been trying to figure this out... Much appreciate the help.
