.NET
C++ to .NET API
1 REPLY 1
tumpliner
198 Views, 1 Reply
C++ to .NET API
I have been programming for several years with the C++ API and am looking forward now to moving to ACAD2008 and the .NET API. I have studied C# and look forward to transitioning to it. I am looking now for some direction as far as sample code and directions on where to look for how to tie the output of my C# compiler (assembly) into the ACAD .NET API.
1 REPLY 1
cadMeUp
in reply to: tumpliner
Have you done any programming in C#?
It is not very difficult to set up the references. The ObjectARX SDK will create project starters for you depending on if you use VB or C#. The references to AutoCAD's assemblies are already there when you create a project and you just code away. There are also NET samples included in the ObjectARX SDK.
”Boost
