.NET
c#.net .GetXDataForApplication ?
5 REPLIES 5
1011 Views, 5 Replies
How do you get, and iterate through, object xdata in c#.net?
Sample code would be a huge help - please...
Thanks...
5 REPLIES 5
[code]
using System ;
using System.Collections ;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.ApplicationServices ;
using Autodesk.AutoCAD.DatabaseServices ;
using Autodesk.AutoCAD.EditorInput ;
[assembly: CommandClass(typeof(ClassLibrary.Class))]
namespace ClassLibrary
public class Class
static public void PrintXdata()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptEntityResult res = ed.GetEntity("\nSelect entity: ");
if (res.Status != PromptStatus.OK) return;
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction tr = db.TransactionManager.StartTransaction())
Entity ent = tr.GetObject(res.ObjectId,OpenMode.ForRead) as Entity;
if (ent != null)
ResultBuffer xData = ent.GetXDataForApplication(null);
if (xData != null)
foreach (TypedValue val in (IEnumerable) xData)
ed.WriteMessage("\nCode = {0} Value = {1}", val.TypeCode, val.Value);
tr.Commit();
[/code]
Alexander,
I am trying to become a proficient AutoCAD programmer using the C# language.
I'd like to commend you for always posting such complete code.
John
wrote in message news:5345593@discussion.autodesk.com...
[code]
using System ;
public class Class
if (ent != null)
if (xData != null)
val.Value);
tr.Commit();
[/code]
With my english grammatics it is easy post complete code then explain how it work. 🙂
Well, with my limited Russian / Ukrainian vocabulary all I can say is
Spaceeba! 🙂
wrote in message news:5345613@discussion.autodesk.com...
work. 🙂
Hi, John Reiger!
JR> Well, with my limited Russian / Ukrainian vocabulary all I can say is
JR> Spaceeba! 🙂
:-D In Ukrainian it will be "Dyakuyu"
Best Regards,
Alexander Rivilis.
”Boost
