.NET
.NET
Valued Contributor
0 Kudos
Post 21 of 26
Re: C# code without start external program
08-30-2012 03:21 AM in reply to: Alfred.NESWADBA
If You
I'm no C#-man, but try that:
1) which language do You write programs ?
2) which language do You recommend to learn ( I wonder about c# and later c++ to learn c languages )
I would like to have that knowledge like yours in programming without checking codes. :smileyhappy:
This code for c# works for first time.
Thank You for your help and time which You spent on my situation.  :smileyhappy:
1,210 Kudos
Post 22 of 26
08-30-2012 03:38 AM in reply to: pipu123
most apps I write in vb,net. the times I use C# or even C++ are very rare, so I'm really unused to that.
If you want to go as deep as ObjectARX then C# would be ok, but don't think that the step from C# to C++ is easy :smileywink:
If you start with VB.NET or C# does not matter, long time ago I read a book about VB.NET and there where 25 reasons why to use VB.NET and not C#. I'm sure if anyone is very familiar with C# he/she will find 25 reasons to run C# better then VB.NET. :smileywink:
At least it's not the syntax of a language that makes you strong in programming, nowadays with dotNET it's the knowledge about the framework and it's technical possibilities it offers. If you know the framework in it's depth it does not matter wether you use it's functionality from VB.NET, C#, F#, J#, .... The result is the same.
- alfred -
Alfred NESWADBA
Valued Contributor
0 Kudos
Post 23 of 26
08-30-2012 04:07 AM in reply to: Alfred.NESWADBA
There are different languages for specifing using.
Friends recommend me to learn languages kind: C like C, C++ , C#.
They claim c# is the easiest to learn from them and later try to learn more difficult c++ and C.
I work in civil engineering industry, it becomes not stable, low pay jobs.
There are big requirements for starting people.
I would like to learn languages of kind: c. They told me, there are more jobs for languages kind: C.
Another friend writes codes in C for electronic microcontrolers - it takes many years to learn this.
So for autocad it doesn't matter which language do you choose.
In other industries it makes difference.
I will start programming in DOT NET , .dll using c#
Thank You for help.
501 Kudos
Post 24 of 26
08-30-2012 09:05 AM in reply to: Alfred.NESWADBA
Broken link  :smileysad:  And note the lock symbol, and Read Only status on the file while debugging:
Oh, and note the 2008 version.  Maybe they changed that in the 2010 release.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
1,210 Kudos
Post 25 of 26
08-30-2012 09:19 AM in reply to: dgorsman
sorry for the broken link, may be to many links in this thread :smileyhappy:
Now >>>that one<<< work. (hopefully :smileywink: )
- alfred -
Alfred NESWADBA
501 Kudos
Post 26 of 26
08-30-2012 10:51 AM in reply to: Alfred.NESWADBA
Thanks, that one is indeed functioning.  And I may now have reason to upgrade VS, *after* I get this Win7 upgrade out of the way.  Too much grey hair already...
