.NET
^C^C^P in .net
5 REPLIES 5
wesbird
551 Views, 5 Replies
^C^C^P in .net
In my AutoCAD .net application, I user COM interop to create some menu items. when I add the escape string "^C^C^P" before my command string, it does not work.
I change to
Convert.ToChar(3)+Convert.ToChar(3)+Convert.ToChar(95)
which does not work either.
what should I do?
here is the code:
[code]
public void AddContextMenuItem()
Autodesk.AutoCAD.Interop.AcadApplication acadApp;
Autodesk.AutoCAD.Interop.AcadMenuGroup mnugrpRAA;
acadApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
mnugrpRAA = acadApp.MenuGroups.Item(0);
// Menu
Autodesk.AutoCAD.Interop.AcadPopupMenu mnupop;
try
mnupop = mnugrpRAA.Menus.Item("TEST");
catch
mnupop = mnugrpRAA.Menus.Add("TEST");
string strCmd;
Autodesk.AutoCAD.Interop.AcadPopupMenuItem mnupopItem;
// todo ^C^C^P
// Menu
strCmd = Convert.ToChar(3)+Convert.ToChar(3)+Convert.ToChar(95) + "LINE" + Convert.ToChar(32);
mnupopItem=mnupop.AddMenuItem(mnupop.Count+1,"Draw Line", strCmd);
[/code]
Thank you very much
Merry Christmas
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
5 REPLIES 5
dmarcotte4
in reply to: wesbird
Try
strCmd = "\x001b\x001b\x005f" + “LINE” + “\x0020”;
Daniel
wesbird
thank you, it works great
Wes
Sorry. I can't run it. It appear "Interop" is not in the "Autodesk.AutoCAD" .What kind of reference should I use? thanks a lot.
wesbird
in add references:
COM tab
ObjectARX 16.0
AutoCAD 2006 Type Library
Thanks a lot. But this way only can be used in the menu. Waht I want is in the program I want to stop a program befor I SendStringToExecute to execute. Is it possible? Thanks in advance.
”Boost
