.NET
Message 1 of 11
924 Views, 10 Replies
C# Api?
Is there an API I can download so that I can program autocad apps with c sharp?
Also, does autocad use DirectX or OpenGL?
Thanks in advance,
Devin
10 REPLIES 10
Message 2 of 11
ObjectARX supports C# through what are commonly called "the .NET wrappers";
the .NET wrapper assemblies ship as part of AutoCAD.
Dan
wrote in message news:5129385@discussion.autodesk.com...
sharp?
Thanks in advance,
Devin
Message 3 of 11
I have autocad, but is there a list of which files are which? So I can reference the wrappers in my C# projects?
thanks,
-Devin
Message 4 of 11
acmgd.dll and acdbmgd.dll in you AutoCAD directory.
Tim
http://www.theswamp.org/~tim/pyacaddotnet/
wrote in message news:5130195@discussion.autodesk.com...
thanks,
-Devin
Message 5 of 11
Can you show me how to connect with the application that way? Once I have the app I should be OK. But is there a good book for managed autocad?
Devin
Message 6 of 11
Is there is problem with the samples that are
included with the managed wrapper API in the
ObjectARX sdk ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5130521@discussion.autodesk.com...
Devin
Message 7 of 11
saluki
Below is a link to the help files/sample files
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=773180
You can also look in
D:\Program Files\Autodesk Product\Sample\Autodesk Product API\CSharp
for additional samples.
Good luck
Message 8 of 11
That directory I don't seem to have.
Message 9 of 11
saluki
It may only be 2006/2007 products
does your product have the NETLOAD command?
Message 10 of 11
No it doesn't . How does this apply? By that I mean, do you have to compile your project to a specific format or just to a dll class build?
-Devin
Message 11 of 11
NathTay
This means you only have the ActiveX API to use and will have to compile an exe or an ActiveX dll for use by VBA.
Regards - Nathan
”Boost
