.NET
Active Member
everts
Message 1 of 7 (184 Views)
C# and AutoCAD 2009
184 Views, 6 Replies
10-22-2008 09:50 AM
I am using "AutoCAD Civil 3D Land Desktop Companion 2009", i wrote a simple program for Land Desktop 2006 using .NET framework 2.0 (VS2005) and I want to migrate it to this new version of CAD, but I am not able to use the program, I can not load the form, I changed the old references to acdbmgd and acdbmgd to the newer ones, but it does not work. Do I need to use the .NET Framework 3.0? Or do I have a problem with CommandMethod? Is it different to show a form with this new version? I am sorry about my english
*Tony Tanzillo
Message 2 of 7 (184 Views)
Re: C# and AutoCAD 2009
10-22-2008 09:55 AM in reply to: everts
There are some changes to the API between 2006 and later
releases,
which may be the cause of your problem.
You would need to show what error messages you're getting in
order
for anyone to help you.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Active Member
everts
Message 3 of 7 (184 Views)
10-22-2008 10:43 AM in reply to: everts
When I execute the command "netload" to load my dll and try to execute my personalized command (sondeos in this case) CAD show the following message: "command sondeos not found"
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using System.Windows.Forms;
namespace Sondeos2._0
public class Principal
[CommandMethod("sondeo")]
public void mostrarFrmSondeos()
Form1 myForm = new Form1();
myForm.Show();
*Joe Sutphin
Message 4 of 7 (184 Views)
10-22-2008 11:04 AM in reply to: everts
I notice that you typed "
face="Times New Roman" size=3>sondeos" twice in your message. However, the
command method does not have the "s" on the end of the name. Could it be this
simple?
Joe ...
When
using System;
using
using System.Text;
using
namespace
Sondeos2._0
myForm.Show();
Active Member
everts
Message 5 of 7 (184 Views)
10-22-2008 11:50 AM in reply to: everts
no, sorry, my mistake when typing the message, that is not the problem. I will install VS2008, just to check if the problem is the Framework version
Member
CougerAC
Message 6 of 7 (184 Views)
10-22-2008 11:53 AM in reply to: everts
Make sure Copy Local on acdbmgd and acmgd is set to False.
Also, you shouldn't show your form by calling form.Show().
You need to use either:
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog (form)
or
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog (form)
Also, check the Error List in Visual Studio and resolve any errors/warnings.
Finally, check your acad.exe.config file to ensure that you are not explicitly specifying a lower runtime than you are compiling for.
Good Luck,
C
*Tony Tanzillo
Message 7 of 7 (184 Views)
10-22-2008 11:57 AM in reply to: everts
This has nothing to do with the framework
version.
Things to check:
-   Using CommandClass attribute anywhere in
    the same assembly
size=2>requires that it be used
    on every class that implements
commands.
-  The assembly contains a class that implements
    IExtensionApplication,
size=2>whose Iinitialize() method
    is throwing an exception.
-  Running your code in the debugger, with
the
   'CopyLocal' property of references to
acmgd.dll
   or acdbmgd.dll set to True.  Set them
to false.
through 2009
When
using System;
using
using System.Text;
using
namespace
Sondeos2._0
myForm.Show();
