.NET
C# and ActiveX
7 REPLIES 7
Message 1 of 8
dnlo
568 Views, 7 Replies
C# and ActiveX
What is wrong with the code, I have an error at runtime at the last line:
AcadLine lineInSset = (AcadLine)ssetObjectAll.Item((Object)i);
Console.Write("n\{0}", lineInSset.Angle.ToString());
//ssetObjectAll - selection set that contains line entities
// i - index of entity in sel.set
ActiveX help says that Line is accessible through sSet.Item() method..is it something wrong with the cast?
Thank you
7 REPLIES 7
Message 2 of 8
in reply to: dnlo
Break up your code first:
AcadEntity entity = ssetObjectAll.Item(i);
AcadLine line = (AcadLine) entity;
What is the _exact_ text of the error message?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5133905@discussion.autodesk.com...
Thank you
Message 3 of 8
in reply to: dnlo
I would say that it make problems that you have written "n\" instead of
"\n".
Roland
Message 4 of 8
dnlo
in reply to: dnlo
The error message is:
the object referenced has not been instantiated.
When creating line object with addLine method it is OK.
Extracting object from selection set as AcadEntity OK as well.
But how to convert AcadEntity/IAcadObject to AcadLine in order to get start- endPoints??
Message 5 of 8
in reply to: dnlo
Maybe this entity is not line?
Message 6 of 8
dnlo
in reply to: dnlo
It is line, entity type AcDbLine. Drawing database contains (testing time) only line entities..
Message 7 of 8
in reply to: dnlo
The typecast to AcadLine should do that:
If not, step through the code with the debugger
and see if the line variable is getting set.
wrote in message news:5135379@discussion.autodesk.com...
Message 8 of 8
kahekman
I was programming in LabVIEW, I was able to take the objectID and then from the ACADdocument I was able to use objectID to Object to get the pointer to the line.
”Boost
