.NET
Active Contributor
dnlo
Message 1 of 7 (126 Views)
C# and ActiveX
126 Views, 6 Replies
04-06-2006 12:50 AM
What is wrong with the code, I have an error at runtime at the last line:
AcadLine lineInSset = (AcadLine)ssetObjectAll.Item((Object)i);
Console.Write("n\{0}", lineInSset.Angle.ToString());
//ssetObjectAll - selection set that contains line entities
// i - index of entity in sel.set
ActiveX help says that Line is accessible through sSet.Item() method..is it something wrong with the cast?
Thank you
*Tony Tanzillo
Message 2 of 7 (126 Views)
Re: C# and ActiveX
04-06-2006 08:30 AM in reply to: dnlo
Break up your code first:
AcadEntity entity = ssetObjectAll.Item(i);
AcadLine line = (AcadLine) entity;
What is the _exact_ text of the error message?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5133905@discussion.autodesk.com...
Thank you
Distinguished Contributor
RolandF
Message 3 of 7 (126 Views)
Re: C# and ActiveX
04-06-2006 10:13 AM in reply to: dnlo
I would say that it make problems that you have written "n\" instead of
"\n".
Roland
Active Contributor
dnlo
Message 4 of 7 (126 Views)
Re: C# and ActiveX
04-07-2006 12:23 AM in reply to: dnlo
The error message is:
the object referenced has not been instantiated.
When creating line object with addLine method it is OK.
Extracting object from selection set as AcadEntity OK as well.
But how to convert AcadEntity/IAcadObject to AcadLine in order to get start- endPoints??
Alexander Rivilis
Message 5 of 7 (126 Views)
Re: C# and ActiveX
04-07-2006 12:51 AM in reply to: dnlo
Maybe this entity is not line?
Active Contributor
dnlo
Message 6 of 7 (126 Views)
Re: C# and ActiveX
04-07-2006 01:32 AM in reply to: dnlo
It is line, entity type AcDbLine. Drawing database contains (testing time) only line entities..
*Tony Tanzillo
Message 7 of 7 (126 Views)
Re: C# and ActiveX
04-07-2006 06:00 AM in reply to: dnlo
The typecast to AcadLine should do that:
If not, step through the code with the debugger
and see if the line variable is getting set.
wrote in message news:5135379@discussion.autodesk.com...
