.NET
C# AddToModelSpace
1 REPLY 1
wojciech_janik
690 Views, 1 Reply
C# AddToModelSpace
I have some experience in vb.net, now i'm learning c#. I tried to translate my vb.net code to c# but I get an error:
 Cannot convert method group 'StartTransaction' to non-delegate type 'Autodesk.AutoCAD.DatabaseServices.Transaction'. Did you intend to invoke the method?
What am I doing wrong? Here is a code:
        public ObjectId AddToModelSpace(Database DBIn, Entity EntityIn)
            Document doc = Application.DocumentManager.MdiActiveDocument;
            using (DocumentLock acLckDoc = doc.LockDocument())
                using (Transaction myTrans = DBIn.TransactionManager.StartTransaction)
                    BlockTable myBT = DBIn.BlockTableId.GetObject(OpenMode.ForRead);
                    BlockTableRecord myModelSpace = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite);
                    myModelSpace.AppendEntity(EntityIn);
                    myTrans.AddNewlyCreatedDBObject(EntityIn, true);
                    myTrans.Commit();
                    return EntityIn.ObjectId;
1 REPLY 1
_gile
in reply to: wojciech_janik
With C#, when you call a method without argument, you must explicitly write the empty argument list: ()
Transaction myTrans = DBIn.TransactionManager.StartTransaction()
This clearly differentiates calling to methods without argument and calling to properties. I also differentiates a calling to a function (to get the returned value) and the using of a delegate (passig the function name).
Gilles Chanteau
GileCAD
GitHub
”Boost
