.NET
Valued Contributor
0 Kudos
Post 1 of 2
C# ActiveX
432 Views, 1 Replies
08-30-2012 03:06 AM
I created windows forms , I add reference to activeX
  The AutoCAD type library, acax17enu.tlb, located at <drive>:\Program Files\Common
Files\Autodesk Shared.
The AutoCAD/ObjectDBX Common 17.0 type library, axdb18enu.tlb, located at
<drive>:\Program Files\Common Files\Autodesk Shared.
It works the same way as vba built-in autocad application.
I wrote that program with autodesk help.
1)      How to define  Pkt1, Pkt2 to create a line ?
2)      Is there any documentation for activeX C# ?
3)      Which forum is appropriate for ActiveX C# and other external programming languages
Thank You In advance
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
namespace Wst_zelbet
    public partial class wst : Form
        public wst()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            AcadApplication objAcad;
            AcadDocuments colDocs;
            AcadModelSpace Mspace;
            AcadLine acLine;
            AcadDocument ThisDrawing;
            objAcad = null;
            const string strProgId = "AutoCAD.Application.17.2";
          // Get a running instance of AutoCAD
        try
            objAcad = (AcadApplication)Marshal.GetActiveObject(strProgId);
       catch // An error occurs if no instance is running
            try
            // Create a new instance of AutoCAD
            objAcad = (AcadApplication)Activator.CreateInstance(Type.GetTypeFromProgID(strProgId), true);
        catch
          // If an instance of AutoCAD is not created then message and exit
            System.Windows.Forms.MessageBox.Show("Instance of 'AutoCAD.Application'" + " could not be created.");
          return;
            // Display the application and return the name and version
            objAcad.Visible = true;
            // System.Windows.Forms.MessageBox.Show("Now running " + acAppComObj.Name + " version " + objAcad.Version);
            // Get the active document
            ThisDrawing = objAcad.ActiveDocument;
            ThisDrawing.SendCommand("MyCommand ");
            Mspace = ThisDrawing.ModelSpace;
            object Pkt1;
            object Pkt2;
   // please define these points
Pkt1 = ....
Pkt2 = ....
        acLine = Mspace.AddLine(pk1, pk2);
            ThisDrawing.Application.ZoomAll();
            ThisDrawing.Regen(AcRegenType.acAllViewports);
double[] tPkt1 = {10,10,0};
double[] tPkt2 = {20,15,0};
acLine = tMSpace.AddLine((object)tPkt1, (object)tPkt2);
Valued Contributor
0 Kudos
Post 2 of 2
Re: C# ActiveX
08-30-2012 03:22 AM in reply to: pipu123
