.NET
7 Kudos
Post 1 of 4
bug in layout.GetViewports
294 Views, 3 Replies
06-26-2009 12:25 PM
i have a (or any) drawing which i just opened with contains several layouts and each has viewports, i run my program to list the layout with viewport will only get the first layout. until i go activate all the layout in autocad and then run the following code then i'll get what i want. basically the getviewport will not get any layout viewport except for the first one.
Public Class frmZoom_Cross_Sections
_
Public Sub Zoom_XS()
Dim form As New frmZoom_Cross_Sections
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(form)
End Sub
Private Sub Zoom_Cross_Sections_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
lvwLayout.Clear()
Add_LVW_Columns(lvwLayout)
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase()
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim ldic As DBDictionary = CType(trans.GetObject(db.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
For Each entr As DictionaryEntry In ldic
If entr.Key.ToString.ToUpper <> "MODEL" Then
Dim lo As Layout = CType(trans.GetObject(entr.Value, OpenMode.ForWrite), Layout)
Dim oID_Col As ObjectIdCollection = lo.GetViewports
If oID_Col.Count <> 0 Then
Dim id As Object = oID_Col.Item(0)
Dim PSVport As Viewport = CType(trans.GetObject(id, OpenMode.ForWrite, False, False), Viewport)
Dim olvwItem As ListViewItem = lvwLayout.Items.Add(lo.LayoutName)
olvwItem.Tag = id
End If
End If
Next
trans.Commit()
End Using
End Sub
Private Sub Add_LVW_Columns(ByRef lvw As ListView)
lvwLayout.Columns.Add("Layout Name", 100, HorizontalAlignment.Center)
lvwLayout.Columns.Add("ObjectID", 100, HorizontalAlignment.Center)
End Sub
End Class
Civil 3D 2014
Work: i7 4770, SSD, 16GB, K2000, Dell PH2414H
Home: i7 3930k, SSD, 16GB, GTX 590, U3011
New Member
0 Kudos
Post 2 of 4
Re: bug in layout.GetViewports
06-26-2012 09:03 PM in reply to: wang890
I'm confused by the same bug!
171 Kudos
Post 3 of 4
06-27-2012 02:38 AM in reply to: specterer
Try this code, tested on A2010 only
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using System.Collections;
[assembly: CommandClass(typeof(FormViewPorts.frmViewPorts))]
namespace FormViewPorts
    public partial class frmViewPorts : Form
        public frmViewPorts()
            InitializeComponent();
            this.listView1.Clear();
            this.listView1.View = View.Details;
            this.listView1.FullRowSelect = false;
            this.listView1.Columns.Add("Layout Name", 300, HorizontalAlignment.Center);
            this.listView1.Columns.Add("ObjectId", 200, HorizontalAlignment.Center);
            this.listView1.SelectedIndexChanged += new EventHandler(listView1_SelectedIndexChanged);
        private void frmViewPorts_Load(object sender, EventArgs e)
            this.Hide();
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary layoutmgr = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead) as DBDictionary;
                foreach (DBDictionaryEntry entry in layoutmgr)
                        Layout layout = tr.GetObject(entry.Value, OpenMode.ForRead) as Layout;
                        ObjectIdCollection vids = layout.GetViewports();
                        if (vids.Count > 0)
                            ObjectId vid = vids[0];
                            Viewport pvport = tr.GetObject(vid, OpenMode.ForWrite, false, false) as Viewport;
                            ListViewItem lvi = new ListViewItem(layout.LayoutName);
                            ListViewItem.ListViewSubItem svi = new ListViewItem.ListViewSubItem(lvi, vid.ToString());
                            lvi.SubItems.Add(svi);
                            this.listView1.Items.Add(lvi);
            this.Show();
        private void listView1_SelectedIndexChanged(object sender, EventArgs e)
            if (listView1.SelectedIndices.Count > 0)
                MessageBox.Show("Layout Name: " + ((ListView)sender).SelectedItems[0].Text +
                    "\n" + "Objectid: " + ((ListView)sender).SelectedItems[0].SubItems[1].Text);
        private void button1_Click(object sender, EventArgs e)
            this.Close();
~'J'~
Valued Mentor
53 Kudos
Post 4 of 4
06-27-2012 07:50 AM in reply to: wang890
I think that is normal and done for performance reason, and do not remeber if there is a system variable, but try using Database.GetViewports() and pass true for argument if you want viewports associated with layout.
From docs
Input flag indicating whether to return paperspace viewports associated with layouts
This function enumerates the Viewports in a drawing.
You can also find your answers @ TheSwamp
