.NET
Distinguished Contributor
jmaeding
Message 1 of 6 (208 Views)
Break points not stopping code on modeless forms
208 Views, 5 Replies
03-08-2012 04:20 PM
I am using acad 2012, and VS 2010 (C#) on win 7 64 bit.
I made a form, and showing it as modeless via Application.ShowModelessDialog... as recommended by everyone and that works fine.
I have a button that does something, and I set a break point right on the first line of code for its callback.
The button runs fine, but VS is not stopping at the break point.
Is there a different technique required when debugging modeless forms?
thx
internal protected virtual unsafe Human()
http://onesmallstepforcad.com/
have you set Framework4 as the current Framework for your project?
If you don't want FW4 then a good point to look at: >>>here<<<
And NEXTFIBERWORLD could be a point-of-interest, look to >>>this issue<<<
- alfred -
Alfred.NESWADBA
Message 2 of 6 (196 Views)
Re: Break points not stopping code on modeless forms
03-09-2012 12:01 AM in reply to: jmaeding
- alfred -
Alfred NESWADBA
jmaeding
Message 3 of 6 (181 Views)
03-09-2012 08:34 AM in reply to: Alfred.NESWADBA
yah, setting framework to 4 did the trick.
The other options Kean mentioned are less desirable.
Wish I could stick with 3.5, as 4 is not always on a given machine.
Guess I can switch back before deploying.
Thanks a bunch for your reply, i was worried about this last night.
Alfred.NESWADBA
Message 4 of 6 (169 Views)
03-09-2012 12:53 PM in reply to: jmaeding
If AutoCAD 2012 is installed, then Framework 4 is installed, it does not run without! :smileywink:
- alfred -
Alfred NESWADBA
jmaeding
Message 5 of 6 (167 Views)
03-09-2012 12:56 PM in reply to: Alfred.NESWADBA
I lose track of what needs what. I program for 2009 and 2012 so I will just target each project for correct framework.
thx
Alfred.NESWADBA
Message 6 of 6 (165 Views)
03-09-2012 01:08 PM in reply to: jmaeding
check the bottom of >>>this link<<<
...and for 2012 you need 4.0
- alfred -
Alfred NESWADBA
