.NET
Bounding Boxes around Blocks.
2 REPLIES 2
GrzesiekGP
2444 Views, 2 Replies
Hey!
I have question - we have two lines which are crossing.
Now I want to find bounding box as shown on the picture.
Do we have some special methods (in AC) which can help me or I must find bounding points manually?
Thanks.
2 REPLIES 2
norman.yuan
in reply to: GrzesiekGP
Since the picture you show is in a twisted angle, we need to clarify it first (that might be why people seem unwilling to reply to this seemd simple question.
I assume the entities (line, or block reference...) you as interested in getting their bounding box are drawn normally in World Coordinate. The picture you show is just a twist view. And also, by "Bounding Box" we mean it is an rectangle with X axis as 0 degree and Y axis as 90 degree, which just big enough to cover the said entities.
So, it is very simple: each entity has a property GeometricExtents property, which is Extents3d type. Therefore, as long as your code get to the entities in interest, you will know each entitiy's bounding box. if there are multiple entities in interest, you simply aggreagate each entity's bounding box. Following code will draw the bounding box of selected entities:
    public class MyCommands
        [CommandMethod("GetBound")]
        public static void RunGetBound()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            ObjectId[] entIds = SelectEntities(ed);
            if (entIds != null)
                DrawBoundBox(dwg, entIds);
            Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static ObjectId[] SelectEntities(Editor ed)
            PromptSelectionOptions opt = new PromptSelectionOptions();
            opt.MessageForAdding = "Select:";
            PromptSelectionResult res = ed.GetSelection(opt);
            if (res.Status == PromptStatus.OK)
                return res.Value.GetObjectIds();
            else
                return null;
        private static void DrawBoundBox(Document dwg, ObjectId[] entIds)
            using (Transaction tran = dwg.TransactionManager.StartTransaction())
                Extents3d ext = GetBoundBox(entIds, tran);
                Polyline poly = DrawPolygon(ext);
                BlockTableRecord space = tran.GetObject(
                    dwg.Database.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                space.AppendEntity(poly);
                tran.AddNewlyCreatedDBObject(poly, true);
                tran.Commit();
        private static Extents3d GetBoundBox(ObjectId[] entIds, Transaction tran)
            Extents3d ex = new Extents3d();
            foreach (var id in entIds)
                Entity ent = tran.GetObject(id, OpenMode.ForRead) as Entity;
                ex.AddExtents(ent.GeometricExtents);
            return ex;
        private static Polyline DrawPolygon(Extents3d ext)
            Polyline pl = new Polyline(4);
            pl.AddVertexAt(0, new Point2d(ext.MinPoint.X, ext.MinPoint.Y), 0.0, 0.0, 0.0);
            pl.AddVertexAt(1, new Point2d(ext.MinPoint.X, ext.MaxPoint.Y), 0.0, 0.0, 0.0);
            pl.AddVertexAt(2, new Point2d(ext.MaxPoint.X, ext.MaxPoint.Y), 0.0, 0.0, 0.0);
            pl.AddVertexAt(3, new Point2d(ext.MaxPoint.X, ext.MinPoint.Y), 0.0, 0.0, 0.0);
            pl.Closed = true;
            pl.SetDatabaseDefaults();
            return pl;
Hallex
Try this code, quick and dirty though, but it should work,
you can simplify them to your needs
        [CommandMethod("BBO")]
        public void testBlockBound()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            //Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            BlockReference clon = null;
            doc.TransactionManager.EnableGraphicsFlush(true);
            try
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect block: ");
                peo.SetRejectMessage("Only a block instance !");
                peo.AddAllowedClass(typeof(BlockReference), false);
                PromptEntityResult per = ed.GetEntity(peo);
                if (per.Status != PromptStatus.OK) return;
                ObjectId id = per.ObjectId;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    if (ent == null) return;
                    BlockReference bref = ent as BlockReference;
                    if (bref == null) return;
                     clon = bref.Clone() as BlockReference;
                    clon.Rotation = 0;
                    clon.TransformBy(ed.CurrentUserCoordinateSystem);
                    tr.TransactionManager.QueueForGraphicsFlush();
                    Extents3d ext = clon.GeometryExtentsBestFit(ed.CurrentUserCoordinateSystem);
                    ext.TransformBy(ed.CurrentUserCoordinateSystem);
                    Point3d p1 = ext.MinPoint.TransformBy(ed.CurrentUserCoordinateSystem);
                    Point3d p3 = ext.MaxPoint.TransformBy(ed.CurrentUserCoordinateSystem);
                    Point3d p2 = new Point3d(p3.X, p1.Y, p1.Z).TransformBy(ed.CurrentUserCoordinateSystem);
                    Point3d p4 = new Point3d(p1.X, p3.Y, p1.Z).TransformBy(ed.CurrentUserCoordinateSystem);
                    pl.AddVertexAt(0, new Point2d(p1.X, p1.Y), 0.0, 0.0, 0.0);
                    pl.AddVertexAt(1, new Point2d(p2.X, p2.Y), 0.0, 0.0, 0.0);
                    pl.AddVertexAt(2, new Point2d(p3.X, p3.Y), 0.0, 0.0, 0.0);
                    pl.AddVertexAt(3, new Point2d(p4.X, p4.Y), 0.0, 0.0, 0.0);
                    pl.Closed = true;
                    pl.ColorIndex = 121;
                    pl.TransformBy(ed.CurrentUserCoordinateSystem);
                    Matrix3d rot = Matrix3d.Rotation(bref.Rotation, bref.Normal.GetNormal(), bref.Position);
                    pl.TransformBy(rot);
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    btr.AppendEntity(pl);
                    tr.AddNewlyCreatedDBObject(pl, true);
                    doc.TransactionManager.FlushGraphics();
                    tr.Commit();
            catch (System.Exception e)
                ed.WriteMessage("\nError: {0}\n{1}", e.Message, e.StackTrace);
            finally
                if (!clon.IsDisposed) clon.Dispose();//optional
”Boost
