.NET
Bounding Box values
6 REPLIES 6
562 Views, 6 Replies
Bounding Box values
Im new to autocad customization and i am working on modifying a code written in .Net.I want to ask how to get the bounding box of a block and also im unable to locate autocad customization help file.Can anyone please suggest where should i search for it.I dont know how to look for api help.
Gulzar
6 REPLIES 6
_gile
For the BoundingBox, look at the Entity.GeometricExtents property.
You can find some docs and tutorials here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Thanks a lot for the reply. I will try that. Can you please suggest me where to search for the documentation in my machine. I tried searching in the autocad installed folder but couldn't find it. I want to know where I can find .Net api.
_gile
You won't have any .NET/ObjectARX documentation on your machine if you didn't install it by yourself.
Download and install the version(s) of ObjectARX corresponding to the autoCAD version(s) you're using from:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
In the newly ObjectARX 20XX created folder(s), the 'docs' sub directory contains the chm help files (arxmgb.chm for the .NET API).
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Thanks for the reply. I have installed the above files. I had a doubt if objectarx and .net api functionality is same.
Gulzar
_gile
The managed AutoCAD .NET APIs are mostly wrappers for the unmanaged ObjectARX ones.
See:
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/index.html
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Ok thanks a lot 🙂
”Boost
