.NET
Bounding box of Text
2 REPLIES 2
wesbird
602 Views, 2 Replies
in my post below:
http://discussion.autodesk.com/thread.jspa?threadID=458585
I ask the bounding box of TEXT and MTEXT. I already get MTEXT figure out. Now I still have problem to get the bounding box of TEXT (DBTEXT).
did anyone know the solution? I appreaciate your help.
Thank you
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
in reply to: wesbird
See atached file.
I'm working about it yet.
tp
escreveu na mensagem news:5106021@discussion.autodesk.com...
in my post below:
Thank you
Wes
Reference AcMgdInternal.dll (where Acad.exe is),
then use this:
using Autodesk.AutoCAD.Internal;
Point2d Utils.GetTextExtents(ObjectId styleId,
string TextToMeasure, double Height);
styleId is the ObjectId if the text style,
TextToMeasure is the contents of the text,
and Height is the height of the text.
If the text has a width factor <> 1.0 then
you need to scale the Y ordinate of the
resulting Point2d by that factor.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5106021@discussion.autodesk.com...
in my post below:
Thank you
Wes
”Boost
