Dynamic block?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6329278@discussion.autodesk.com...
I have a plugin for AutoCAD that, for some block references (with a specific
XData), exports them to another application.
The code is very simple: for each block reference to export, it interacts with
it's block BlockTableRecord and exports the geometry (lines, circles, etc.) and
the BlockTransform matrix associated with it.
It works out correctly but only in 95% of the cases, particularly, in the one I
attached an image of.
In the image there are 2 block references (to the same block) and the exported
data of one of the blocks is mirrored in the Y axis. I've looked at every
property of both block references and I can't find out what is different in the
mirrored one (their ECS are the same). I simply can't find out what more I have
to use, besides the BlockTransform matrix to get the correct transformation.
