.NET
Active Contributor
deepa
Message 1 of 11 (103 Views)
Block structure in VB.net
103 Views, 10 Replies
02-13-2007 10:53 PM
How to get the number of levels for nested blocks in VB.net
Distinguished Contributor
Patrick Johnson
Message 2 of 11 (103 Views)
Re: Block structure in VB.net
02-14-2007 08:44 AM in reply to: deepa
You are going to need to set up a routine that is recursive.
You are going to need to search each blocks table record for blockreferences.
pat
Patrick Johnson
Message 3 of 11 (103 Views)
02-14-2007 08:45 AM in reply to: deepa
pat
Patrick Johnson
Message 4 of 11 (103 Views)
pat
Patrick Johnson
Message 5 of 11 (103 Views)
02-14-2007 08:47 AM in reply to: deepa
pat
Patrick Johnson
Message 6 of 11 (103 Views)
02-14-2007 08:55 AM in reply to: deepa
sorry for all the reply's internet problems
pat
Active Contributor
deepa
Message 7 of 11 (103 Views)
02-15-2007 08:55 PM in reply to: deepa
thanks patrick.but i need the details.can you pls show some examples?
Patrick Johnson
Message 8 of 11 (103 Views)
02-17-2007 07:51 AM in reply to: deepa
here is an example of recursive programming
Public Function GetNestedBlock(ByRef obj1 As ObjectId)
' recursive programming (calling itself)
Using DB As Database = HostApplicationServices.WorkingDatabase
Using Trans As Transaction = DB.TransactionManager.StartTransaction()
Try
Dim bRef As BlockReference = Trans.GetObject(obj1, OpenMode.ForRead)
Dim BTR As BlockTableRecord = Trans.GetObject(bRef.BlockTableRecord, OpenMode.ForRead, True)
Dim ID As ObjectId
'looping thru to grab all the objectid in the table on the block reference
For Each ID In BTR
Dim Ent As Entity = Trans.GetObject(ID, OpenMode.ForRead)
'is the selected entity a block
If TypeOf Ent Is BlockReference Then
Dim BlkRef As BlockReference = Ent
//your code//
GetNestedBlock(BlkRef.Id)
Next
Catch ex As System.Exception
MsgBox(ex.Message)
Finally
Trans.Commit()
Trans.Dispose()
End Try
End Using
End Using
End Function
pat
www.cadenhancement.com
Active Contributor
deepa
Message 9 of 11 (103 Views)
02-19-2007 02:43 AM in reply to: deepa
thanks a lot patrick.but i am not pass the object id i am passing only the block name.
Public Function GetNestedBlock(ByRef blockname As string)
and also i am not clear //your code.
for example Block_abc is having two Levels (blocks) namely Block_123 and Block_xyz.
How can i get the Level of Blocks in nested Block.Pls help me.
Patrick Johnson
Message 10 of 11 (103 Views)
02-19-2007 01:25 PM in reply to: deepa
I just sent you an example.
\\your code is the area for code to figure out what you are trying to accomplish.
For instance you would want a counter to count the number of levels until you find the block you are looking for
pat
Post to the Community
New Post
Need installation help?
