.NET
Valued Contributor
Ertqwa
Message 1 of 5 (349 Views)
Block size
349 Views, 4 Replies
03-24-2013 05:01 AM
I want to determine the size of a (non-dynamic non-annotative) block definition (BlockTableRecord). Does a block have a boundry or limits?
For example, if the block would contain a simple square, the size of the block would be equal to the size of the square.
Thank you.
You can check bound property of block as well:
 [CommandMethod("bsz")]
static public void BlockRecordSize()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = HostApplicationServices.WorkingDatabase;
PromptStringOptions pso = new PromptStringOptions("\nEnter block name:");
pso.AllowSpaces = true;
PromptResult res;
res = ed.GetString(pso);
if (res.Status != PromptStatus.OK) return;
string blockname = res.StringResult;
ed.WriteMessage("\nBock name entered\t{0}\n", blockname);
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt= tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
if (!bt.Has(blockname))
ed.WriteMessage("\nBock \"{0}\" does not exists.\n", blockname);
return;
BlockTableRecord btrec = (BlockTableRecord)tr.GetObject(bt[blockname], OpenMode.ForRead,false);
Extents3d? bounds;
bounds = btrec.Bounds;
if (bounds.HasValue)
Extents3d ext = bounds.Value;
double width = ext.MaxPoint.X - ext.MinPoint.X;
double height = ext.MaxPoint.Y - ext.MinPoint.Y;
ed.WriteMessage("\nBock {0} hase width= {1:f3}; height = {2:f3}\n", blockname, width, height);
else
BlockReference bref = new BlockReference(Point3d.Origin, bt[blockname]);
bounds =bref.Bounds;
bref.Dispose();
tr.Commit();
Alfred.NESWADBA
Message 2 of 5 (341 Views)
Re: Block size
03-24-2013 05:06 AM in reply to: Ertqwa
do you look for that?
Public Overridable ReadOnly Property GeometricExtents As Autodesk.AutoCAD.DatabaseServices.Extents3d
     Member von Autodesk.AutoCAD.DatabaseServices.Entity
[EDIT] sorry, I saw to late that you wrote "block-definition", not block-reference.
So you can either scan through the elements within the blockdefinition or you create one reference virtually and take that reference for .GeometricExtents. [/EDIT]
- alfred -
Alfred NESWADBA
Hallex
Message 3 of 5 (319 Views)
Re: Block size
03-24-2013 09:19 AM in reply to: Ertqwa
            PromptResult res;
                    return;
                Extents3d? bounds;
                else
                    bref.Dispose();
                tr.Commit();
Valued Contributor
Ertqwa
Message 4 of 5 (285 Views)
Re: Block size
03-25-2013 01:35 PM in reply to: Hallex
Great, both replies are what I am looking for. Ty!
Hallex
Message 5 of 5 (277 Views)
Re: Block size
03-25-2013 02:16 PM in reply to: Ertqwa
Glad you got it working
Cheers :smileyhappy:
