.NET
Mikko
248 Views, 1 Reply
Block Scale
I'm all tangled up here and can't see the light. Anyone know how to set the scale when the block is inserted?
Public Function MyBlock()
Dim db As Database = HostApplicationServices.WorkingDatabase()
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Try
Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
Dim btr As BlockTableRecord = trans.GetObject(bt(btr.ModelSpace), OpenMode.ForWrite)
Dim br As New BlockReference(Pt1Res.Value, CreateMyBlockDefinition())
br.Rotation = angR
'br.scale = ???
MyBlockId = btr.AppendEntity(br)
trans.AddNewlyCreatedDBObject(br, True)
trans.Commit()
Finally
trans.Dispose()
End Try
Return MyBlockId
End Function
1 REPLY 1
Mikko
in reply to: Mikko
Got it.
Dim theScale As Scale3d = New scale3d(somedouble, somedouble, somedouble)
br.ScaleFactors = theScale
”Boost
