Hi Guys,
I am writing code to create a new block based on an existing block. and place this new block on top of the existing one.
Here is my code
Public Function FixtureConditionOverLay(objID as objectID) As Boolean Dim db As Database = acApp.DocumentManager.MdiActiveDocument.Database Dim trans As Transaction = acApp.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction Const strFDName As String = "FixDefects" Dim strDefectBlockName As String Try '--Get Block Ref Dim objBRef As BlockReference = DirectCast(trans.GetObject(ObjID, OpenMode.ForRead), BlockReference) '--Check whether the blcok is exist strDefectBlockName = objBRef.name.tostring & "_" & strFDName Dim objBT As BlockTable = db.BlockTableId.GetObject(OpenMode.ForWrite) If objBT.Has(strDefectBlockName) = False Then Dim objBTRHatch As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) '--Create a block Dim objBTR As New BlockTableRecord objBTR.Name = strDefectBlockName Dim objIDs As New ObjectIdCollection objIDs.Add(objBRef.ObjectId) Dim objHatch As New Hatch objBTRHatch.AppendEntity(objHatch) trans.AddNewlyCreatedDBObject(objHatch, True) objHatch.SetDatabaseDefaults() objHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI38") objHatch.PatternScale = 1 objHatch.Color = Autodesk.AutoCAD.Colors.Color.FromRgb(20, 30, 30) objHatch.Associative = True objHatch.PatternAngle = 90 objHatch.Annotative = AnnotativeStates.True objHatch.AppendLoop(HatchLoopTypes.Outermost, objIDs) 'error here eInvalidInput objHatch.EvaluateHatch(True) objBTRHatch.AppendEntity(objHatch) trans.AddNewlyCreatedDBObject(objBTR, True) End If 'Insert the Block Dim myBTR As BlockTableRecord = objBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite) Dim objNewBlock As BlockReference = New DatabaseServices.BlockReference(objBRef.Position, objBT(strDefectBlockName)) ' myBlockRef.ScaleFactors = New Geometry.Scale3d(XScale, YScale, ZScale) objNewBlock.Rotation = objBRef.Rotation objNewBlock.Layer = STR_LAYER_FIXTUREDEFECT myBTR.AppendEntity(objNewBlock) trans.AddNewlyCreatedDBObject(objNewBlock, True) trans.Commit() Catch ex As Exception Debug.Assert(False) Debug.Print(ex.Message) trans.Abort() End Try End Function
But got problem here
can anybody help me?
Thanks very much
You need to do the ObjBTRHatch.AppendEntity (and preferably the AddNewlyCreatedDBObject) before calling AppendLoop.
Thanks for reply.
I have done those, you can see from the code. I still got error
Any one can help me?
Well, I see two of them in the code now, I didn't see the first one before. So that's a problem. You can only call those two once for each object. I think I see what the problem is though. It appears to me that your ObjectIDCollection only contains the ObjectID of the BlockReference. I'm not sure if it will accept a block reference as a valid boundary object, so try exploding the blockreference and passing the objectids of the contents to the AppendLoop method.
Thanks for your reply.
I have tried to Explode the original object. And still the same problem on the same line.
Here is my new code
Public Function FixtureConditionOverLay() As Boolean Dim db As Database = acApp.DocumentManager.MdiActiveDocument.Database Dim trans As Transaction = acApp.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction Const strFDName As String = "FixDefects" Dim strDefectBlockName As String Try '--Get Block Ref Dim objBRef As BlockReference = DirectCast(trans.GetObject(MyBase.ObjectID, OpenMode.ForRead), BlockReference) ' Using lock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument Dim tv() As TypedValue = objBRef.XData.AsArray m_enumFixtureDefect = tv(INDEX_XDATA_FIXTURE_CONDITION_STATUS).Value.ToString '--Check whether the blcok is exist strDefectBlockName = m_strBlockName & strFDName & m_enumFixtureDefect Dim objBT As BlockTable = db.BlockTableId.GetObject(OpenMode.ForWrite) If objBT.Has(strDefectBlockName) = False Then Dim objBTRHatch As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) '--Create a block Dim objBTR As New BlockTableRecord objBTR.Name = strDefectBlockName Dim objIDs As New ObjectIdCollection '--Yaqi Test Dim objDBs As New DBObjectCollection objBRef.Explode(objDBs) For Each objDB As DBObject In objDBs objBTRHatch.AppendEntity(objDB) trans.AddNewlyCreatedDBObject(objDB, True) objIDs.Add(objDB.ObjectId) Next Dim objHatch As New Hatch objBTRHatch.AppendEntity(objHatch) trans.AddNewlyCreatedDBObject(objHatch, True) objHatch.SetDatabaseDefaults() objHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI38") objHatch.PatternScale = 1 objHatch.Color = Autodesk.AutoCAD.Colors.Color.FromRgb(20, 30, 30) objHatch.Associative = True objHatch.PatternAngle = 90 objHatch.Annotative = AnnotativeStates.True objHatch.AppendLoop(HatchLoopTypes.Outermost, objIDs) objHatch.EvaluateHatch(True) objBTRHatch.AppendEntity(objHatch) trans.AddNewlyCreatedDBObject(objBTR, True) End If 'Insert the Block Dim myBTR As BlockTableRecord = objBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite) Dim objNewBlock As BlockReference = New DatabaseServices.BlockReference(objBRef.Position, objBT(strDefectBlockName)) ' myBlockRef.ScaleFactors = New Geometry.Scale3d(XScale, YScale, ZScale) objNewBlock.Rotation = objBRef.Rotation objNewBlock.Layer = STR_LAYER_FIXTUREDEFECT myBTR.AppendEntity(objNewBlock) trans.AddNewlyCreatedDBObject(objNewBlock, True) trans.Commit() ' End Using Catch ex As Exception trans.Abort() Catch ex As System.Exception Debug.Assert(False) Debug.Print(ex.Message) trans.Abort() End Try End Function
Thanks again
